Lan-renewal of door trim, rubbers, clean and regrease of mechanisms,...
deQuincey
Quousque tandem...?
yeah, another big and long one, enjoy...(or suffer ?) ;-)
a spring is missing here...
yeah, the car was originally white...
my god ! what a dirty lock mechanism ! in fact it was blocked and i can not use the key to close it !
a broken door stop..
postion marked before dissasembly
regrease and new bolts and washers (mr. arde said once something about endorphines and new spares... I agree with him)
Good timing, as I have to take my panels off to change my door brakes. I gotta know, in the first shot, how did you know where to find the hole to Pop the Chrome piece out? (Of the window vent knob)
Just slide it around the back until you find the hole. But it is not necessary to remove that or the ashtray to remove the panel-it has cut-outs for them so it slides out from below.
I guess I am still in my Monday Dunce mode.
as i have explained before my right side door stop is broken, moreover looking at it now in the picture, i am noticing that it was wrongly assembled
some months ago, in a trip to germany i found some NLA, NOS door stops, these are original door stops for e9, but for the 2000 version as is clearly stated in the bag, it seems that it doesn´t fit for our 3000 bodies:
there are some differences that can be told from the pictures
but the most remarkable one is that the size of the base area that gets in contact with the door panel is different, bigger in fact, that does not allow you to place it correctly, so i have to work a bit taking material off to accomodate this
so to copy the old shape, i put one against the other in the vice and fix both with bolts
and using a file...it is aluminium, so the work is not hard
now it is modified to correct shape:
compare my two new door stops, the lower one has been modified to fit in my e9
once assembled, perfect fit, perfect function
it is nice to have this working, i have not had a door stop in the right door since i bought the car
deQuincey,
Although I would not wish worn-out or broken parts on any car owner, I always look forward
to your repair/re-furbishment projects.
I really appreciate the detailed photographs you share with all of us. They are very useful for
reference purposes as the many times copied repair manual illustrations aren't often very clear.
The door project is one that I will be tackling myself very soon...to clean/grease window
mechanisms and to replace missing door panel fasteners.
Also one of my chrome door panels strips (the long one one the lower half of the door panel)
has come loose on one end. Is there an easy way to reattach it? It seems like the little
metal attachment prongs only grab the door covering material, not the door panel itself so it's
starting to pull the door covering out. The chrome strip itself might not be perfectly flat too.
Visit to Greenville, SC
Dear DQ:
Perhaps I could entice you with a trip to beautiful Greenville, SC. I could take you on a tour of the BMW factory up the road and a nice drive up the Blue Ridge Parkway. All I would expect in return is a few weeks in my garage sorting through my car.
I'm joking of course, but your work here almost gives me enough courage to try and do some of this work myself. Great stuff and keep up the good work (although I too secretly wish more stuff would break on your car)!
Benji
deQuincey,
this is the part itself, after removing the rust of the attachment plate (the one that has the prongs), i applied rust converter and them i painted with zinc paint:
the part is very long and now is good, eventhough not perfectly straight, but when i removed from the door trim it was really bent
the unbending work is really a difficult one, you must go little by little using a piece of wood fixed to the vice, and a cloth wrapping the wood to avoid scratches, then it is better to do a little be less than needed, check, and do it again, have a flat surface close to your working area to check
if the prongs are not attaching the chrome strips to the cardboard, it might be because the cardboard is destroyed, and thus the prong is making the pressure to the cloth through the destroyed cardboard
it is no other way to fix it but removing the whole panel out
any alternative way that tries to fix it will result in a damage in the mentioned prongs, and they are not easy to fix or substitute
IMHO...
Dear DQ:
Benji
thanks benji, i accept your proposal ;-)
i hope your secret wish doesn`t come true !
it is my pleasure to take the little more extra work of taking pics and posting all this explanation, as i see that it is helpful for others
thanks Gary too
regards
new issue, the trim panel
i need to remove the cover to reuse it in a new panel
i tried to remove all, including the felt,
but it has been imposible, the felt is glued to the panel due to heat in long lines (i guess the cause was the production process), so i had to remove one from the other, i used a hot air gun to help
cleaning:
copy the deteriorated panel in new fresh material
deQuincey,
Once I remove the door panel I'll check the size of the holes
in the cardboard.
My metal strip with the prongs is coated with surface rust that I''ll
need to clean up too. Most of the prongs have to be straightened out to looks like yours before I try to reattach the chrome strip to the panel.
pete
I restored my panels almost the same as you, I just keeped the last layer of card board so the felt stayed . I used aluminum panels for my door card, it wont warp now ever. I Enjoyed your post.
thats correct skin,felt, and just one thin layer of the cardboard. DQ thanks for your posts!
