***SOLD***** Getrag 265/6 5 speed transmission
Getrag 265 5 speed transmission pulled from a 1982 BMW 528e.
Yes, I know, it doesn't have the speedo provisions, yet I DO have the following brand new parts:
- speedo gear
- seal
- spacer
That you can easily retrofit on there. I do NOT have the actual pinion gear, but you can use the old one from your 4-speed easy enough.
See this article on that: http://bmw30cs.blogspot.com/p/5-speed-conversion.html
Transmission is in good to very good condition. Drove the car (the cluster showed 161k) extensively before parting just to test the transmission and all the gears shift nicely even when driven aggressively. All shifts were smooth and there were no unusual noises through any of the gears.
Transmission had Redline MT-90 fluid in it when drained and it was clean with no signs of metal or burning.
Asking $750 plus shipping from Seattle, WA
Comes w/mounting bracket, couple rubber mounts, and shifter plate as shown here:
- speedo gear
- seal
- spacer
