"Mad Max's " S54 powered E9 project
Keshav
Germany
There is some person on German eBay selling the 4 wood pieces for the doors and rears. Has them in both, light and dark wood for €150. NMNA. Excellent condition.
Keshav
JohnFBD
Sydney, Australia
I have the exact same Arc Asylum subframe, would you have the dimensions of how far back it needed to go? Good news is I have plenty of access :)
e30strube
Houston, TX
Did you use E36 M3 mount arms? They bolt right up and seem to place the engine in a different spot than the stock arms at least.
bdigel
Atlanta
yes , once we got the subframe in the correct location, we were able to use stock e36 mounts .
za2zbl9WG3_RiNZbEqv8ZZh2EE2e8RXrbOlo3DERIukQzAxFdTF4s8IwvJk5JSVVXtLWIsKl8cN52qZDL4OpEVYh9gPxajCEElgymMt6qMi8LiryfGuCM42fvDpM9AvpLIsBiwn2GswXukt29nM3RBOrOzjzHyl00aZiBTbiPNFGNlcK8CFUHX2jiKOFp3prDwVscwiwGddiDJijWJ1snQuwdJ4jvASwgm4bCgkaVzbBEl_EGkiC_uK9Bdl_r8d2gyDU7enCDV3fy86DkviNNwGSjkckM3ZBas1ZxEMtaVDpWyjIu3fiJmukPgL7ZYHJM_qP7rLigQdovX12Kd_aZBR7iASQV1mjUyOa7GqvgmJKj5sHEBUjlW-2-Tlwj_FPiqld_19yZpaKBnHLLCeWEAPDuDH0p8otDS9h4Y2dj3wGA7PZcqyc1zKtDklJy8JxzbPA60l8yIc8PQw3P5PggTNP_3djsQ6b_WsDNOFpfZ8WS5f6qOoF1N2KXiDSy5XDSSin08PEX0xFVnFcezK-tyRflp-pl5UzCYlA0DZiPxTMCXl0MnAplsVGIeXkZWdsCBA9_2bVpRbTjf9YshIns639JhHRDVPRhc2_Zkm-4mISIvEFDAXg=w795-h597-no
after getting the trans mounted , next was to get a shifter built. We had to cut , shorten a late mode shift tower , then cut and shorten a shifter linage to fit that tower, and the last step was to make a bracket that held up the tail of shift tower
YcWGrHrjhHvESQyGAF8kcL01DmDJV3Qw4Tq44wG-OOsxJ1h0crFczlwxjkDf-F9qBbZyUN3eWrOHnbAAsy7XwChu3qgjAtHgoJxIThEfrZ9rWzhY573EO3Fm4op1qSvr2nsNRki-ZC2a_p5DamlYb7gxbkngFQBYunHFw6L5fXVO-uv-_JENF1Lrv-fYBHwjKouWVzQzwThdnyfmsq-Sp5rjY9S9WZJ4X56BfetZ2FGqUnvX0hImExIMz7QDlZ1pUFiu0bhE3m_LnyqMUsMcryS3bcD-ePSQJnLhfvK28glJH5lcUosXJzSpASd0W1eHAJPyI1FC6M85xXbcnwkNQIuWVeluCjykDe3edUfPIP_DBOqN_XnvKGRm1fe0sOXDdP9q7NLk38xsnZ95B6JV-YqG6KltugCNCRKVlKC4u_YAmLkCm5PdNioC-Ll4GUFyZMKifo8GQcfHph1E083akbZmYQScPbN91zn-wxllDc2Mc2kbV63jOCgRqNdvvZ5eOVMr76PzpONYltztx3kT4j6Ywy9EMrSC0_jQVvevXMALGrB3Lr553upwzxAeJe6s-ujRLVp_gUN2oe7aHPrY_srGJs05qRnp7oeK_XQpjwwtS1GxtBUN=w795-h597-no
modified tower and linkage
T_2ATnXKOOHBwbDQGdRu-enCTZPAxSTXt3KRgiLC5PyfwpV3whyFTZZ4ascAeSB4oKkDiZFnsDyiuxuK-oSyVAqUQEP7TnO2Hc8QR-XfsumTQKL1QLH4ft-vMf4CgMPaEjTBiAKdVTQzhkrI4fJsIv7atIak9-y-KB2Gul8q4uj1cbhVpl-44_0yw0eGPld1WunnJe9jLuOWlQK4_hkZwGt7ALTiiogn8JLEiCW3_Q9Sw73G_Fgbkc1jUx-HCBx3hM2uQXIf-Difs_B95UxmLb07ldA83zgceRZa0S6LQntFoGwIj1B4UftsPgYKsOpfaWQsHFmFL9fBQWIsmhYTM-jz5ZRxfZLOaCAx0AGb-1uErrhecAmQr5G997EaM3MP3abP4jAu6vghYFXgo49eUN_pOIApYpOsX_kQX3ku8VEJ8k3lMAfAIF5htED266X0njaAI670pPohxYzU8N7QuSmCwzH1r1qcLw6Pglo8z9vKj7a4jd97bb76-En57NvkXz5Hdie1rZRafjHjwjYZXV0xGbyH3oHZzJHYI_ghnkjIfmm5zjX4sdq2EZcueftxyupzQIjtuukZhJgoTgeCsz0cwJFDynPyatBmFoAWXWImFTt0=w795-h597-no
shortened tower
qMxjfENaH9Z8qL5rFln0hBwWqSWsNLxnFc-RATzuIAtSD8iiymkCTFyD25UCRkPOPjV73WnUX5Mvc8o4v3YuajuA6KDOLshvJgjJJUN_KD4UcDhrppSKrFQkRMt0kWggHwrup9lRoMH-oYLWTG0S5F9D4wzgNosel6RqFEqYnCnIK_kQdN96PDTc2imh6rbBedXETRO0t3V01ZiddGSIRoVtkGBrUkQS906QElg1EaugKlJfG_Ri8SR0AnvMmqUx78eyFbSXxoOPd5oRO9g4YL_WSrtivBIcYMkDkNVMh7kwc-TUP1xkXEWD3qh_4aFexG3X9qTemewTXuM3ovYd0MP0sePQov-x4fts-kTG1H5ahwNE281TKI4ZfBV2aBpjklbke3GsXXO_wenDWankMn_k-fE6ARhrXGe-Ocuq1G56RnNtQqyCmOGsXOESnX8FpdNflTBFAtTmp8HxLSLqs8iTAMCuWSjgkiIRnWTqUJLDBqwafvP2K6SXw5llg-UsQF1rWwPS8Ia43-y__ZUXV6H-YRtogUQHB160NLpVaXOMJds5a4-wJGVr0iz_oZ4s0ZRf04dXJRcoLHSErEmXo_DneJ6nA8PcRLcEU3CefUIyQXgj=w448-h597-no
tower and linage installed
8u4CclqPJ8js2kQfUlu8Elu_oPwth_cLMhHUACbzC3R2kV4iLo2GSAsJrA640iXY0BACcXUIlWiQoUODPMPb524z7hS0zqLJa_NorbXta4NrvlL2RenXP_XWjBqk9e2E1gusl3gAmoC13fmPsPSK3vpjdT_qeGtOiEXvQRJ8igL12rqrauFaI_ET_jEVG5obKrCrewxY0tGTADOKPAHbVRZRTXmRk6GHjM8urAQAONg8NUzITSi0ZcFP8lC9fsJE5PYissYmG2_8NU4QyUk1BJzEgvErJ4vFGRH0rnAEOqJKZmFwALdAm0lDJ5PimK8vszyPVIcu29FhAeP-ccl_2HRaGZqEVi0cwdYDCuFwaAPsNzB4GCq5D_D9K7om36hdhqpzjW9Ftmol8r2hlxBX07f5pE_29HGMPK6RVVkkcN4pqX4H3Hswk8wPkkvpPC9kzVEK1SzT6xFCllQ2k9PhR0wx95Tjuox5pee73ZdJf2Drb4p7ymGLYac9AkgMyPYSH6ypYQkdzR3ZK-r3DG9h2fvLZP9IStnSihfhU2xRUDNb1zkgIv36m6uGBONOSz96swRORhp_0317f4gpeDqPm8FAc6PjtLPzNfZgZeL_9QJdE_7IxH5q=w795-h597-no
Prepping for tower bracket/ mount install
5KE1VCAfOnzWl8B8x0dSKO3vQWUWskfDUobHUe_WPYKwGZrKsN3QRw-1Y0sHKdculkmYvZp5lbZR0xssCEi8O4GOE505djQc0hYYDWegxy_LfRGEmvHCh45iYLCE3RT4d6hERQ94XmT7onAFccuk5tXfYAZZiGjS8SFmg9imZIqRKYmebhpnuOHVBOLsI8KDlLQ2qMr6DJGG0ypaltCXXGMtkWIPHqLNPPxsala8THhnzQKBLDHuj11ezs9fEEWpe-Gs5tT9gxUm2Tp9JsUDzmTHbV5dKYIlrgaKzaVnD__6zgRmuNkFaqG904zjfEyRucc9czX2JN89GFoz0WFtVZU10Yq0xGqJuAp8zHFQU1EsgUEW0aqi-1VMffG3pXowXt5rZaFZpmqxqCC2lBuqJ9SgjGR0WecJjkpRJrkACKLxEaUf1SchbGBWI87FJkpMkYRsrS-sbpc_94qLcUg1M34ek013EhV0J0Bo9MtZRXkGms3picnrwVcDqK0AJfjv_hsnCrT3eEMm7P40ai8Sc_Dum1hjs3Y0UGsoc7CFT1IEyD7VJ6YVI3SyX5Xj15fG9xWxKfijXdjPDcZT74_0rkx0qx1AdGovGpBzzu7C8CX3RQxeM28J=w795-h597-no
Shifter is done
xf4IZGc5xaLVedJV3HMHnO2t3RFJxUHWbX3Ir5jHCndKty4_AyaMkjskZZWn-Ul6T9eDz-Be9xliojyhex_Njk9gI2rr2BJfDDXn2D2JfvZOd4TwZzv9_2TL-8pwAPR6ML5s6bNq7CI7asuEvHqoj_1HfBY7MzF9qG6gcNI1VR5Wkr8x1wdfdMHpiP_GxvytL7IUfLnvaNckYwCWevHl9XPEwmzPhvuER2myGTpifvoOQuKequvcGZuRPh_279JMQxwYmBE1Sg43UNWfDxhZQcDuQxOjHmE3paU4QM_38JJnY_fTpJKbRWHGGTb-WcuAnJiXCtpMbNmpC5s8XTVZedLQp-0pXhl2_et3WoYrjwxSaV-r5Tqk7LOOWYhaRbq7IXR7dJZIQnkf_GSwe2uGeIveSJeXOdSoHfG_DywnhwXkJlMTr2zPLEG-dR5DdXTP9H-LkW9_flZ2gg_4gzTBiZ2ULJMoMLxYF23uJAUNhewDrI7ACg9vgsx7KhEqlYofIl-6OaznhCzPG6HD8XoXvcedq7yy14Vmix-d2rzOUdZrs8BmiuuDho3EeFGr3RuYx10oub6ZjZUBhRDWDVvUAL_pS-IN4f--0ODVoeJD7A75dXrQEBNA=w795-h597-no
Next problem was the driveshaft center support bearing mounts were in the wrong place, cut out the old new and fabbed up some new ones from scratch and welded them into place ,
zKog0AwtuiI9LC2BdyU5zOmJgcRrxYTalxPp3bxylKWUJcsbeAIU4XNdsQNE__Tcq4xG9RAebpiajCbhAARpavvOcoVCFKeni559cpY8mvURYBYNRdp6N102qa6ZvySFrWdKz-C816IohQ1taNmAQMWpu1h82B0jyucaeZNi3l9N8iWJ-F0hIzA-0KH8lHWJV7N_hT22L55WWsOXEywnUCOzmVWNrFPBw8atd1XfIYKTukvI1yL7uF5AgXBkCHXBXF2Qn70xcxugwInU7FS6YCyxzjuqBbcPb6zeOVPhKeB9dSum6cSvDxVkNm-2uaBzg_UUwOkPN_p_Qi9SNpzq0apiOqsY_N0DcFQKA2wQ_LYUy8GeGpq2Zv0nlALXnRCdIfg45jAc-9HppEPnFWcN6QOodMs0LnLB9W8CHkLOIcQecWffII2HXnj6eXmpI83zl2NyjHPjtawoGGhzk37na5HEeuacYdsriQ0tSM4VSnmKldLsWKuHL_N-FWXmDYb7CjYUaxfkAfs8NWAfptCHvoz6MniKp4tWruMXhRLgeh1OVU49M1GlWudjXI7N2Vd0fFBlwXn9gtBt2FQ7JArMJs3rv07sCTKc8ckW8cDyyDwfkTAA=w448-h597-no
vKPjmm9WSzLETsl5GRjznERwmnFaRMOrCVnggHYT8ytXfQK1khUN8JbynNT1qZmir1TfutKnSrxHZAOI3C18gZmVTLdyqhu1-aU4zXfzy9DkFIbxNPcTl1E13mZ2-njIWACkAum8-6S9zPOL5e-9GdC9znSL96TjDF3jRuWk0XEk8D5VArfrRaONDj-Ts7EHd25zlY68hp1ipI5KbXbhZc2sCp9LDO7FmsjiTIZDnk1rmlhwO0eFRWenxDrKYhmZmZJ92DgT8lFseayk3hAg9uaizwDJz6PF6EfJ4pQgmBT_WCXdv9Z-_RiI-1HdrGwU33LPVbhfqBHMrkIAs4M8Q3NRlohrCT8cHLXSy3MCIDRPE6NPIX3O9iSv1PNLXHMXPxnzpa96bRWv1bDjaWGuTieZ_WdW0zsASXV18W_BqNGOKN7qfcCn2Mdzop_5PbR__tfbnmQGOH2UzGwLMwbG-rIy2qZRfcjlHzvJSdMAi6i1PIxiX1ZZg_HgxPCDLZBzyqCjCBxhl2JN69QMSvEHs3-WmLg6O1m29cDMAON2jR6FwfQoPGIxZ7foKvDwFLSPs4_UTSiKjY6TKqi-89ZsJykqus6Qx_7eyr_GghDcE_44QOxx=w795-h597-no
bdigel
Atlanta
finished up the relocated subframe mounts, "boxed in " the ends of the new pieces
DmYukyJG9fxsVFm9Xn_bKd77a-bJNMpXdH9B6hplEmXkWlkCgTNoE_WjOpRvX1dDM1aZdFqNdnX0dA=w2400-h1350-no
xJUG1Cqsxpve0mYWE2DwWnJyBAqXZP1uzhGzVi_5xaZrFSizuUoqKb_flEoLuJSkpbxd_2A-25Tuew=w2400-h1350-no
the back side of the mount
7dzjQL0x3r84x4-vo6M8ZTt-ex05ueVnD9voKKNRP7cwmapibMM6JHTrabizWtL6KQPmgMGZAH6YGg=w2400-h1350-no
side view of the new part
bdigel
Atlanta
started laying out the cooling system. using an E28 535 rad, and making my own coolant hoses to mount up to the S54
W4WrEhW6TxGlayU8EQXe2TQ6TnaOMpxIwOJTQokbGxBU5IDWOJT-nVhrv_MnfP2Tazwwmaf4Vu8r8g=w2400-h1350-no
E28 rad mounted
t1kto__6_qK8_TYIf98NlfjyinUzWKktZWaLRKIiIb3ww_dhzJP0aCITcz3eOVJ4rRpfkXaDsVA28Q=w2400-h1350-no
Cut off the e9 rad mount and used the e28 parts,
pkMM1WvHqEFtLjV0mA8OEmNfvLH2EtYVm4B9s_kZimxxkqaCCYNvGBO75nOthsjp0mdrTl3jOB4Z5g=w2400-h1350-no
eGu-TvYYjU38J2wDWdJAqcF__H3hS5POZ54zJoiJLIOMh2B7ZCQujijZxxgAKfiPuVeFxAumDqqrWw=w2400-h1350-no
placed the e46 M3 exp. tank where it will reside after I fab some brackets for it
NPdkgZ5HjDLj18-7imhg3Lr4QgcwJmbjdwiXCZbY6zJ8Ic278mi_vcU9cQCfcIOnroEFazFss2i2Kg=w2400-h1350-no
qNbiKVKZlr-mNwfDW_19UIaSC-yEJgBVg9Fwy3EsM5mufHP-KxXpXldBcy3UbfzRJ_2lC1AMqm6EqA=w2400-h1350-no
view of upper Rad Hose , used one 90Degree hose coupled with a 45 , still needs a bit of tweeking
Markos
Seattle, WA
Amazing work!
Heads up that several members are looking for the OEM passenger side radiator bracket.
bdigel
Atlanta
Started on the rear suspension conversion to e28 component's . I had done this on my Green Race car where I felt free to do what I wanted. On this car being a street car I was trying to keep the fab work to a minimum , and bolt on type stuff. It would appear that is NOT possible. I have tried numerous different ways to get this done, and finally just started cutting and fabbing up my own parts to get the e28 stuff to work . If you guys are interested Ill start a new detailed thread how to for e28 conversion . Holler.
the biggest difficultly is the shocks , the e9 stuff has the coil on the trailing arm while the e28 is a coil over, the upper shock mounts are to small for coil over , and the location of the lower mount puts the shock coil assembly at a difficult angle , . I was hoping that we could cut out the stock shock tower and weld in an e28/e12 tower , this still left an undesirable angle and was too short , so we eventually just made our own.
cR97q-CJQ4MUl8rViloAbA_DsLqaWIz5l7-bFMYDMRwZEapMnRU2ptgZtHyDIaM6bWjCtStY77Q5gg=w2400-h1350-no
stock e9 shock tower
rKwtNdmMv4t_J0MH5VF78hPLEh9fh_W2CyajRrM1eQxGP-35Fho5d7EDYCe1wnI70yLpuJcTCSSsdA=w2400-h1350-no
lQlfhMvrnhPlfpsW8AeeSW1hJgGDtSTRa6kdLOUISLJfJ_1aW-i5MpdNSpOvthMMzytgJbEPPYEBKw=w2400-h1350-no
a "mock up stock e28 shock , notice the misalignment up into the stock shock tower, and lack of room for the coil
w0iN4eRPGG0iKXQsiQKmary5kZ74xpn73EEHs-m-Bq37EG4dNqc6kuyA6GuShw2tAPHPHL-GRogJ5A=w2400-h1350-no
Cut out the old tower, and the boxed that it attaches to
_77LsZAYW8xzVqjIKffimPlDa9p5rZIFW1Iiy6ScBYB2RGNgNlUdHbhVazgOmPu9P6UYOHw-_sV0uQ=w2400-h1350-no
the e12/ 28 tower that we tried to make work , but ended up being to short and the angle was too severe for the shock to work correctly
qmjAHt2sMnUlubLxl34w6TvikCifBwCsL7kMIGbTej4_SdG8H3cUyvN11tKuK_wjyVu75Iv5YZ_VaQ=w2400-h1350-no
New coil over shock from Ground control , note spherical bearing lower mount to help with the severe angle
-p7_NudpER9aBzWcHeYC48yrTlU9xFhr3Is2fez89waCtkC2DC9lKfFEdGidKUBNiIsIkgF6e3S2ZA=w2400-h1350-no
Our own shock tower from scratch before getting located in the inner fender
Yh522LO-hNjeZlmbh-guk8f1cT5Ism30VW8jmiSLUwBHZ01HV0hkBdrQouk3FhYAYdcxCaTVqtJyXg=w2400-h1350-no
the new tower tacked in to place
3wGWZf403vFYl8PsXns5fiC3TziokTMszKbbLa_TH_DwXJFZjA-jVpZ7QWzG6p0qX7fs8GVw2gaXeA=w2400-h1350-no
KS3bNbqeJy3ZsIBRD-t4ir82Ts-pezRZCL2Qthhs2VjD-uBuBeWg4p8wByrHAkc9jLy5Ouj-Qz1IVA=w2400-h1350-no
5N7_80b2GxJI7dl55-8wVIwAMH0qMXw3MzBcn0Bc3Z-IijHYSJwVj9irfTujzrVuJTphUfRAVj-Jmw=w2400-h1350-no
everything tacked into place , ready to be boxed in, and welded completely
bdigel
Atlanta
Pretty cool stuff here.
I was wondering, did you look into a z3 rear end as a possible swap candidate?
Mike Yaskin ?? No I had not considered that, , I will have to remember that for a future project .
Today we got the rear shock towers finished up and completely welded into place . Fair amount of work, but turned out nice , now we got the car on the ground in the rear , still have a few issue's to sort out the rear compl
bdigel
Atlanta
kopEje71HUpWuvRzX_p59eAw42spzWeWlPQYylc11RMuPb9b9z8MFJ1AMOUXBU_16FzclrliE2XkfNdjkk-maMWq1i6tZMpJQcTDmC82TxEndqJNB2JpRmRCcSo4DwylFfv-6OfILkoobYqaLPdzfTMxGNePwXxUnfCfuYsKuRBymTX2i-A_nqLhGV92BVlb0DKAeoXfRhypsUHWWbDivAHOXFiFLRaaFgWfpIq1675fn9jX4fBtgmQOSm2FfRyrgacLLgh6iu5iNrNE8qkOOwZgOqTiE4cdAX5aQgfp0Ln4U2oCLOeRPysgwfawCuCXeSH7HuKp9CLyfXvlf-FbOzP6os-GUDFtNiM1RmBymn1nzbSrwH1c2tzst3vEWMnda8IAzCyJk5_rdtTSQtFmNgAlg0CYiykVMPsidxdJVoXARh2RrkZErKWw8u8sb_9jc2DMoN4R-nNMkbsVLov1_SQ_uDZeS2Jx_wOfkSkD6K1is9gXHGNyKDCfizbUja8yuUCbhy28dnIO9dYnJbI1B1iXsg1Qp9i6Q2IAYWwKJIEslKJ4Z9xwXLWZ-Weh1zwIWq7nqak5fcZ-wzqiej19ij30731WZ9YU1HeGGhUspIY2TUBtHArs=w795-h597-no
New tower getting welded in place
iWCH03eAqcvqtfgPXQutcgaI6-5AD22XqWT4OhUNYrYtOc2o8veCYszhDqLCTsHO5lUkAS2ohAxpOYDRx9OkBLADT4uhq_4ykdphEugsW618JXxknJPlHpS5oTmx4u7AMszNw0QvAjSK1qYeSGMf9GLvSXQSaEcnDnhhCOKpFbdtvsXhh2t8iZoDjFsjUAPoORadfVhA9SoCCaMuv4u5L3_8WV3OtcyXLv0fqXTM8ZHgB8kUwET0r1GBEAlfMUcqb8RUNRxfpe6zGwIRHLyKCkK55n79mNTkSZjA0KL6Tswu8ICcsj0CBFMgKV4Iy-NWsV5_lXu8ee5UTwi3gNsxRt15GaWD4mZDMbiOB3GFtfOUUzLTgBPkaq_8cDs7thQJdnEM-K2m2B6p5m4D1jqYRDdoWLomNdzOFrFnH5aVZcxYk18BppDEAMxnohdlvBfwT_qbv1brL05S0EU170H2N3rv26tUx7bYY8sYYu4uv8qHmR4CZ1HVxeG_beBTbCTDiYlSWwCJpXUaTPo6dvMnCngekExZOE5_ZSEkn3p96n0jiCNJpuPZRl1-UlmU6SsHsmMTpBWBHXXZq-HiMrU2M0GwSCSxc4R9MrAZCL5DdW6QV5iP9UQW=w795-h597-no
Z6OtSk4d0537LuBwtLPGw-2H4NWBGNsls5R0LW4g2bPuc36HtBY08ESgrSV9KgnsjVVg-SugzcNe2-l4m2vsZr8MTxqzZH_V63BIoQDBnXgkArppLLzYoUfKW7AXFysCMyATLk8wEkJw-zTKk6cS91cNkbe1UKCoXMb6aBzY6B9w1m7V7zubSbvkAvLbiPTeXwC5MImjYMzwpF19Crm6iCveqByBaqqQ4G1bT6IPk1FiHSYQUbleFGHRCm73Hndn6BmKdWu66MDSd9_QnYzidsTXu55dzGqXqnsJRerCPi7JvCgFfmUH1Dytr4hHSRTblw29xs29RR-Diw5FQE84kd5gITkkkX_zxTFiY2_lSBIwKibYZ6KFeUhie4WR2MSwcM0nF4RVhg8Y6h9cmwJ8YUDZDfvnifqx9552ZeJX9Y0zDsKzX9qa-Bwy-mV-k3swXI_b8IjBDHJfuylEGoy6xc5XKxSYFfUbm4mssvY5q_LDL7WO_T_yYu8qz20iPOa1cHcbE7zKlBFPteem_5cDltCszrT8XSFCUZ270ChAJLVUPYxGuUCpUa_5Ehdgg76UnVSgJCmsaM5WYf9WVcIDO0x_v44NoS2-unJ6A-RpF_16G5dA=w795-h597-no
from the top side
GLLFi-RWJluhXcyMRiYb4artMhYle47yAQrepNTTSUNxXkdG3c40y3tOP0rps-8FK-H41TlsP56tKgBESsQMpxig9L93zna69Cak4wr_7abMFahhYZMNgO9qlBKE-avZrS-KnKg3gsE9H8GUKa5Ob2LTnWawdAExZqLce1zWXcRqBhnfoP6mCzhbnpgy3dnVb77TKyndeNpziBSry0r_c9anrMi853riylQe_A84HluvnaF9RZ1YQNbW0BFo4Hg52VbKyVXQCo8dx5xgG2RPXtWrZwAyn22U6r67WkufwHAFWNkG0dRaaTu2Rz7U9O52sXUmzPUnstjxNlzs6kez0zAFjQXsdB0zTOqMcn4sa5XOztDfwFza5_V_IIt7UW_U_8vwUmT0mh3SJzGsQAATMNWJ661oIcZ8T89grstrJHZN1Jo_1YYadnr_8WMqsj7cf8N52MIvH4jhoy0ElcHY0MR2wKI7tKXlpXE06GKQDd3IT1PVjG7LRI2dLN5vnnXN_FgTRQL_w4TPMhvJbdnc0R-Kducw0uJxssL4V3caRKM6QcpRm4h01wkDHpwvGGOwu_kAndGOXdGJIWGsXFYNK4zD0H6pFkednQ2ATLhCbIefA2JK=w795-h597-no
excess trimmed off and completely welded in place
A2J_Iyr47vfRN96Vo9h-h-DcSmbsEVUPB75oyqwx5xB9mtFa85p6q95lJntinHCTYZX5nsGCO95usj2TAOn2kR3KI2fFHJxBQJRYQYr_GBFaKiLxgju22REutxkTTG2eVbowQDakiny1_aCy0PeqTqNFovICG-DAcgv1nnKwrx3ZtIgJOX2q5qd0lmzh1b7glYYcjQPS4NY2vI7NqaqxpW0v5c0QSKWWSIUgQCkgzGRdYAFhxk36C2dFtS18wpJ7TlCEdziUknLv9OI1l38ILAKZPgRQQKr1AJIqj3V88_dqHypks3H6ad_audN48aWvjAv3Mz-xZHQapkzSE9ZbOH8g2jHEZNXcymxCC0GC9eXB9gUFDPa7VbK1N0fRc6cSeczoTHSQ7Ycltlh63W8PrLRwuc3MkBXmMMFftyKIRELcdkk6zLajlf7C80138yWki2tyq45QG8-UnlGZC76KnA4Y9uHXBjpBwu8DLUVQelTYqmJe2BKRXmg8L8FFJOdTcPXi8G2uA3M4p9Iiu2R45ropmnB3C226Q0X9j2Lb_0C8nhAr4tWrNFjg3HokVq6L4nioqjfTI6oux-SY0H1M7E6yN_jkVmH62AIqTU-Ec6spkuaS=w448-h597-no
YdWb0MkU0NGZ221usCzmP6SqcmU5vYMtFQv5zdNwCAAdCzujEPFw4p9A_KuaMHIuuxxcxr_jZy89xTKcioOrP7N-94nRRPmwZgYbXmMq90HY73OySjNymBjgBZFSDuhAvzNdzJZoGveS1bPyiGU3GwyOLCIMUk6PsbzBPqP1IqJmPz7xT8eeiexe6CzEYpEibg2HKawac3wr47l5HrjPaRI23wV73wZz6WUq9zZHujRlwUBl--C8Vv7Wxf3OH0vZm-1fvNAlNr4uBzk11-PPIUqLcu_pgk60gedNN9YUEanJZx4e_PXcXQIieqh1F2SNbaJJs--PHUkA58XleOX0GQnTB3devu_CLnDNNzXcQ-Qm4CW3YlVt2fS-5zfPOM3PYSk1t3DRiq4Lkokk8xEoKRKAVUoAKBK_ITBDMzvVVz-q03kQo3s8OflPcyOL7rfkZxo4jOCHaKZj4yrkpe4IfkfuLCjRU3sAxdPvPDPsL-ppIoFGx9n8kPVpqtCYKxDEZ8HnkJi_goaq3MeHWjvtwkE64Srp_i0zmqXRDZ-17w5e4TTx7aAlnOwx85g6ctPja_x_JbJmkJ7SmY5iSsMEzKKwXtJwqSOWuHaYt_TXa1Qy6B9B=w795-h597-no
V56YV3aM3G37Gml2rHBKYz0KtimHp-YqR6To3jqIlXuJzlzmwAf9HX2uCxU8PoDXCWVlK_bB5GQMPnyZYvZ1QkBNSfQuuv6UoyiuL_4XANlTOz81Z82C0xpVmPccVLhtsc-BC01-rGPVFVc5e2iCSme_Z8T8eFteO0wTyveOuJezWwPMwywv9ESU7wK9vBV52ATJw8kCNae6Cz9k6DWEh84cZrdq3D82OfuqGBNAt_0Btjl50-Sb68v4ZCOPeuGWMcuM73Tz_gezULy8IokEzSehKWFD-znebMySc3uYLzg6iexxL6iJQEYFxvX3xrZCBN3JT5p_ZdoH8h4x29LPm305Q8mIQMZ5XXBJexMMPssZsZaWFBx0Ox88xG11aJmdc1EopsZ-DoTW8A_EBtKS2VUT1bqESAL4AmljFObz47uLOy9cuDa7Gd_TbtXQn9dW0C_0vIsERJiwMdP61E9UDzLnvE7qggfSGSyuhmytWTvF365HPXoen0BisnAvp1qCKtQiPW8CvrZpbshEtRja5xp4XiC2ow3zBI8dEukGojQwdqtxTVt4PUZgPV5BnoRtGPKB8QX5F2LdOMQLs0hOsdRAs9HNmlARUaYhwMN87TibsWwi=w448-h597-no
coil over shock installed
tP4d5q8bjuFwOOanVuEYKPXxdjpTrCxjk6lz8tLf9yRG4SyzANGvKYZRvRCnoWHtzcgmuO2r_DMHtdsrn6S88c_16q7eTrdO90XT5y9VH1oPSb-0C6TeA65V8-LXX1KvRz3Wv06EENI0SsUflPY5hQOG9FaDML99v9ywN_E5D2bLatQGxmH65QRrWEXhN8usNHPJL0c6o9BaBoIiR74PxyYB7CIsrlkz56GX2rLHu-NHb4yFow5Khao7mx-_DA-9ySEP3ZsFN8EUnZqnWzRyUEMq3yWUKO7VfRugK_q2F_lFBS5lL96ZFwh1yyq0NCNEZjBrpKqZmcih_4lFtnBaYOiKiGeZuUKpMHA-03-668d7u5iZq6r5_v4-hJNB5v7E4PI8-Dz63b2zX3_3m4lq04cVltDLHhIdhPsffnvlc3QxA0gNn0K5Eq8XRi144bylL5R6ScWJ4FgZRKDVfL131l4uLpoFGNth5hNa5bY2unphSKDZS7bPPyRgd7VL9QcJvRG9EIslg8bjoqftVvdrigRZy0voRskgPKT6Lj5Io7RqD9-lBa2XUfHjwXcM-oWpyfpzenhU3juLFf23wDmxB4gjVwSoke93uwhMJ_XscJ7tdhr2=w795-h597-no
3fBxa0jX6NYoV3RubWiHfDGmKsxwNe1qmEkaOzHQ_w-C4qh7p8cN3DoLeaL5WMrlmz_6ja51OugMhYG9IEaLDN_eE2idgrslFr6ua4A9IF41j_55Yl-40aJhqAt6aJcMSHShugBkASkCcCIXoXUmP1SD0h81ELZkryIw9rrU-b8gNURIH-P3iyM9ccoKsHKi7mIOgtWkI7tyhT4tNYM3MnsW35YOPylm7UeaqVaThfLl4VBOWryr4TiR33VHr_DArD7WO0KozJ_VZUFwR-9FXHfHQc-f4am0ntp_-fYpSqI88t6cIXSUofn8lD2vU51xadyFmRhGsIivFc1p2oQ5g1k6jl55W-iWyzeCuEpBIe7GG9cfNurzOcuSUPY_qChoHepC_V_SwZNAH63XWukyZfgVEixnC8JWzsc3SD0Nq1FiwLNpiJuQ5uCdAlbyPdjuVfbB36HW-SzuwlECS260Q_D7hkX1pGC96N-5V86qQhhQVaGPvpyU3OKyX3wikEI43ac0zC5YkPcIpilj8YMYu0kz4tRzR0pH5-Lhm0NukoVzJ1XFnWJn0K6PSf94rmpbZc3oYcPuBo0AfkuTJTxy9Fmlbjz2nGXIbSb_m_demjMrcl4k=w795-h597-no
close up of spherical lower mount
tTEzQZKfdaYIWrGlUSZhHU-bhcRZgqaJkYZzInRz-wa1p46Onva6NHRhFN2vCjsNLe-j5R4OxnDG58oMBk4vxqXCSBC7eXdjm6ow4ThN_kEW9ssYVH9ou8bfVdFgivLu1GXK8rGQFfhyiMo2rwpfX4JLjtjjtutW94Qi60nALpi-jTh_Az05ERHASgpmTOXzzQBU8U4t7HjMIlC6Kyisg6tzUD49l_pw7q05P0M05IEF6BrE58lJ6yNzySTlLbCNT9uDanA81rqCdMCZnCpn1IwnncWLAcmejoigyP5vTDgbYzLT4lVGhXh7rslMwqjpgz_Jw62v8NVZXLk6LGHjhNSHGkSDUN2V9E0SDyYLvT_BmnkPiq952CIk_osfboDPz0FooIM-x5x64fwSUEjhOmy1AEXbRuvg6LpMeUgWGMveT074u-T6Me0xOG1LTY8hUgFN0uLY0OPD37kg3v0gTjD9V8O_UEYMuRTxSzVaeWjvA4XJUmk_u7N961hHLy8m_aNPwABAmWuPPAoPlFkOZRCMNfTLYQ3atKJVDwC9p2jsMqmAW0fpxB3lNDrLqXMVriNgt1ue8U0shRbGymU0g1XbZXIKkNRDjVmA5lSagNZrD-ZA=w795-h597-no
had to cut some access holes to be able to weld all the way around the new tower
WH-QTmouRtn7V1qh7Gmk528hNe9JqurbZB8ctoAQwtsLuOOkZmtULHB1Wpf6L3Jev-HgaN-R1MwfmtYDJOo9UZDIR9ptZ5m90EaON3p6xBEyqLrHzXcbg_1oD6x4fY2P_s-AxLaX4tjpo1ePS_St-eMrd7Of2484lAvO0ugVRTKlcoCOf_CJgpSYR4ipPclgtTKXiBAqmDn8_w1Rzl9xDZza0V51GV111IkdPy-hxUViel0pt8aAeI0-JuQvjw0OD6NloQppyX099qNHxmkp_boB5J1enugLoXBWNjRW5ycriJGik79iWWIdHMTBK75MlHsS594VogARi8hciercuLwxI_0uOKU7D9YAw7uwhMrMttvgyseOoBCuUvmE1Mb5rdnAYfLyVxKTggf2gz5-laeA1mLJKBgx1Bc3r05Bu81htB3LrO-t9xK0hO2YJEFkIFpqQpaZc22NuvOCAAw55sN05Qyzia5G86BCRvsE8r299hRbz37x8aOG7CgdGanhBhielloeUQ28KWng0f9GwZgL2UDtyzSwv-PEupb3YffH4fb8lFamimy6WBK2v6UBWDXPUBBL7WlHZ-PvcsQbRNHla3qi0E9_LDGvCoEggoR76DUP=w795-h597-no
complete shock tower
Mug61vsxfk_VrtIviYA0mSEo1UpZZj7R-2ynuJIkYzUjsXb4mHKFCvxwB0ih32Wx6SgrF_248KVxf_g4lu3sUbAWS2oS9mFfiX8j-WIj7GyjIf7ZRFmx2Lq9--r7G2qRR29Pixb9bLerWQMhGN4ssiYy3G_jb2GgPrG_EaucS8orkJ1p7DPxaya4hdWDIEt3BZjUjkUDzwJbCAsmJ5vD3XXxLVJHVi-AV5KD0wlg4LoTpOyqH9W0yIFKobWN0itrErI-12jNmyWbegnA6NPmZvcuMeZnTbvBELVu6Y_LpXHxLomfdTuz0HUbuj0v0f2oWxjSMskvdgwM89R_1c_13_Kai86kcnKhToLVkK1MnL0IITRma7yODmBCqm2TGji_hKtscpfwdmLZS_VjFPeXC7OXRM_7GBrQH3N2iM9-fYgeRW219B4k95gQQVUFi5FrvcFGdw4e6fCZ6cWJf0cQJGBGI3UpvceAi7d0VOLS6aaqJc1itF_8H75rLJw-KaJzlWrDzvSuzcfkSznAx_PqKozzo269_r8r6wdAJP83eJYpuDREq5WMmQt5TOvzeeJa7yhmCP1TOo2vhctd8PO6Ef_ytkJOka3WEJjThpI26zl5DSBD=w795-h597-no
Norristown PA
Am I Mike Yaskin? No. He's at my shop often though. Refers to us as the River People.
I'm working on my first e9 right now. I'm going to attempt a z3 front and rear suspension swap. As I was taking the engine out yesterday, I decided on the front as well!
I love that you're a few steps ahead of me.. so I can follow your lead. Thank you!
bdigel
Atlanta
are you going to add the rear diff brace?
is it already there?
I do plan on reinforcing the diff mount, but in a more substantial manner than you are probably thinking , I will basically have a strut brace in the rear that ties into the diffmount .
another piece of the rear suspension conversion that needs to be taken car of is where the trailing arms mount to the subframe . on the later model subframe's the trailing arm mount closer to the top which creates interference with the body. To take care of this we cut out the stock body /floor panel, and made some pockets for the trailing arms to have a enough clearance to rotate as they should
W9PikywpbiC50ORQJa6smIP3RgTPOV4M5lpFHb1H45l9_NN7UF8jUOaeNyDKGaigamQ8VnqpDdDMQkcDNTq4koqCy2449zZguTWcPVYjszTSP7Czn0yEbZtFpU8wHQx2Jhwnl2qJyED4gujDZfumU2rhVhxUVtD06FvWqqn72s7j6x-5Cek7zlTmy__pQ3TVg4dKXEaBmqaSjZZWuKI6qw98KfDcoHmdlVYwKv4Xyupz8yZkagg-hnxN2X-W16eFpvyRgmfu_wtYkMWRPfxOmIkHpK4U2H1EO7iSPeaphuvmdwQf1XuK2dmycTH1ijHgy6iIudZ6zGAO1XIQajuzCYz_aPbocfyMLPlYLTxpeqXo6Sz5jt3z84x3Yg1bVKhkgto0LVKdG2peIZLCtk8cXsHg9r-6a1vqIAEz3wTO7tVPOMVqe33rpgA8mOzovKPttO10MYj-GzuzpZpOOPZtT0VhZ3aJx2ErlN-rcEra-tFMDJKA8tMshKrXb_wi-PDNzBwjXCApzsLVmhh71JOIZsfCAxqYx0-Uxv9Np7221MPdEuA3dDJrrHE6xAzJBPf7Be6hvkOHZhwvVe_kc_lHELcJNmRw79mLZNqrFEhZ_XfEk7fWdM53=w1280-h960-no
the trailing arm hitting against the body /floor pan
TQRQZPHYhAfBdQ-PpfxJRPsmsZ0aky0Om4pTAM94rgGOg9ImvtiPO6ZSE-1frg2G0ri59M-f5jrBuyWc4Uck1hFSs2AyBDkbGWcGZ3KP5WdBwXk3lNOim1hNscT_Y3H3jhpvP5T0CsQdR1zB9ShAqftJhyD0SPZ7pmV3vDniI3i6FOLeB0IVVoFZVokGqCGFrT8EWTfh1ZQyfKmbYJ-MSfGme5LPbhEv0E131n20tnxnAQ5Ha5u9UrrH0I-9Fnwgavj9oO0F-b73EYo3bUmPHVtkeh7Kp7dogON7TcvMLo1YXd_PLwv4C-1HF4BtRMsm2eB40fLjyFqG-TVjSZVk1DunHrBSK_hWMae9S4MwYlbK-xHI2asJ-JAKMHZJIoPLMIP3648QFeUoxQumMW8zPdIGt6HqCgi3IHDMObckSiR-CqeSSlvES6JSg3FS3NcLRYXSbGsHtkhYl93N2KhT9kijXEoN-P7PpuqW1RwIGSWu0rALYBtJaDL99oDhDxIvpBKqvE8PfBSgmaE1tSfEPNx58Hv4qmdM8-3j5EjtGzEaO5nwGdF1VPEARpyEKHPfZn13TBElRMHDvH6o-05kvRLJNUlsj1zH67gC-3HSyrBQZ8gInhZh=w1280-h960-no
Floor pan before modification
l6sQcrP1s5lR2LwzwqFc5ZbV9CEqMXbs5rhBmFF87V8jcGiVQOzsaJM1UfylrCXPzGdmDJmcaXqWPVp2l3Ux-GGVlq6gb3t0955ueiI1JwC83xtOFZDQkxn7PyrbmI_9N6SR-wgVHqjWqZ55wBgvSbCndpMh72wRYB_C129XZ_gMUauxdvjsjtymvivYSelnv-H5TT4gwgCyR9cbkU0NEUYF0vGA6962Rie8dOiE_juXGLrSsIylGkIaWSTSwMzjMvaCdof6nbCQNwSaknpvSh1Kfan0WTE4bOvZHnB-sSW-zI_XVlRIC6d4hCEpkhUnuGZ1C2o9y6PV1BaQ8g_ewKHHtVwR_x8BWjwin89yLhpIfsIchonQL3ESFhgL6oqSu6NMz_BaxqpZfP1NDBkMc13kqSBodEADpPs4fnJed-G37vWKEAbGeQmCrCF0qManiXQxEDPSGTMyz8ysm4JmJo8BoGCodgkkhK0LjTSiUlQYp5rq9wyOVj-U6WMvLEoLXReFf0R-KmtRhJH6RfNeVekWe3-zxlKGyb8u_XjN3lhSn-PvrM9cgTk0cA09DrcT7aDKQKCd-z-yLYIHxtGhRLIqW_FV-3XsxQx5EGYnIev1h8ED=w1280-h960-no
We cut out the floorpan , note trailing arm pocking though
tjlZVt7-N1wZzhlmkz8dBcSYB5Hbj-Eizb0d_APyX5gKhXsRQUVsMstBv36gGW7I8eQ2Mv9t1Fa5Qo9Gjja03E7SIsPAUS1dQpAW4ZJHgOGZiP_rcMzsoRm4yyPY9tLv2onruDrwe8AG4PSw12JX1xxCwMnBzRycLblBbSW9xrPCWtYEwnXE_L6QcuWeXIDryx_o2LdVIF6HZ8UcN_wrgk4Vn-0bt6Wg3kryv2PAe5TNQGSHnaYlona9xURhqGmffc8P82Fmbr420oSUzla7SzNywHy6vYOQWToM9G1dT9Ps-pqHhWeNm0yuOCd01tVNn1y1l-sUK3vEb7eucqi8GUzN6knSjn7vD6GtPEyIkAayOy77aXGYnh91o9iyyy5Fsz0zUm_H_G9qRVYIjdCtiONXTaftbtFYbfCVNpzut0lVAUjIneteNVejYyYmNMy1sCXxHRK4iRFpBRF8A_JQc8LounGtQm356YlW8MkgK2oe2u94n_JqTs-9-LofmtU67ruRmpka7jVVbNX2yCbhreGLLs_IYBa74xqhs9m9uyXbGcyszqS5N5wT9l5-vuLmsX0N8Mo75gPQb76IFkOsZmhR6iYBG7X4vsR3jD7QkoYRvPBg=w1280-h960-no
-3mzAg1arrYtOHU9h7p2RVSQRCEv42uBwILu1FydTftGVM0AMJQiNKXxeWb_y7CH3heD5FdoQ2UNMZHaMPYELRHYkyB2S2N-9nySyzR19PIliziqxQ3u36COSwu66u00-SABXCa8PQ65FIpFv8CErwnU1CSISVapCSvygbtTLvXhX4aSTg9GdBZuYG7yyNLUbzMUEHYqNJw1_oBIIlzGCV3JjdvXkLThe7jacvyhMdSUpqJXR3uCtA3Tifl5HGWEcBLvLEgHkvRYi6qnKb27nU-MFsEpVxwjnva5rPvXnxALPYZC_R1Fw6IOhHBP460cPpf8PlGzfFDKXyfW37zjHP69BXNO0RTMq4GQfrEP8xMuNyv_D5mt3O0bpvjzJlL5bAwn0LlWVVgrqNy2MUppWrI2BKBW9pIpE0cW3D2Xm_mHkbK3AJ3N8y3nAoF_C5fS6AnF_VoXrO5T7LucEf9aXdJmRMlpLz-VNCsSM8V6QpHTZvwdEsMSuUiYjM4omO2Kp3zu-BF17HDbKnLv2PENzitJ7L4I-Hm76VIUSN8Nd97og7XJI4KeBEG1j8VkGoIIcdTSLoOQfyLeBp50btkrtdJbNL8ETLHRUpvChHLToxXJ-6SM=w1280-h960-no
The pocket we made welded into place
HL56-hrqPCnCI_5GRe_BzotCaV4t0cJvDJrz1CPxM2eY71lzY3RIf1Nc9Wwc8GGP4ohv-FmzS_6UPBmARAb9LVtHwpg1rnZtSLDIUVMP7ESASkWrW5vOJsEy6w2OZb8-fm1tWhM09Sxb8YQ3O4ZT4GjWXD60KX8a78KLqdnUMr29m1JSQRWKcuTXaVSBXnnv-zhYEFBzc7K3mkKWkuPCWtShRWMSUbqcuSJpEouhBITu0DaBTruaaalXr3oe7aY6a5om744OkVfP0qAjqeIewPAqBKpRUcoGeL7r95zgvZjjVrs8fF_hZZRbHFmCrXBbEEiPFNEOvtT2f7v0IFKnyGfEnx22Mz9q3EaIXzzAea-2-lMMVp8r5UMhV9pVyN2upo3QW9UUXguqzgRXc3bczPKsu-8GafQOLC4qbyM2fLZhxufb6Shm7pO5eFkFwh4CLSPp-0jPxWqASh8j-Z-S8vGPaFT9D6RddQlgwDo4KbR9YaVqnzFI-fGwl5R_fFdG0Og82vi20offXAG_oj_wxEmt9ybRTc8EgM9ibzzsvhj3Hqk-wi2aphSItkyzSXgFFl4vcy5lV-vbCJmjt1BR7mv7-3x3WgBwJoUzLDqPzGEWHGXo=w1280-h960-no
SjjyPcEhDl-WXyMYahEGYPI6GOv1GfSz8Zn8EvLSiE5WS5HNCN64thnVGg_sRDEQ153wCyYu3R0AUL74xcIh-1DoyBaOAtMW_xgDy2ERsGEL1Jqc7aW9SE351h62unV-FJKxAyK86SUqggzooMdgi7EtuC7VkvBB92qSLVl_SoFvJUCFdW3h_5El7QaWJ61GYb4zzBM-47fXIvVlAx8mZIqqDompTDNSHcQanT3d_QyimoyfkpmtZyYMGY72_CtkTn8yKygUtyi1I-JeJ-TFQqSVJKjnppDhmUqg8u0M4I6V-B4oqvIlXS8OJwjt2Wfwuao5DOqXVKQnOP-QoqBHXy-tC6X9i-NDnEbQIBYxsnEL7bIVpJGd7XggjerVtOSDii7kJED8ZaCivZ0KEPksN0AIC5S6N2S3544vOZdf5S553fEKjGiTCpTBinnRwwd7-4whXZ_xPaZgrCXFt9sRCCBvB8iWTH_zvkihv9e5DnrQO8Y0kMWKmXxkrpiR-HmA4K5QsezuqY8Qj1ttKKdYF6cSibOZ5xdX2MuJj_yv5meW3UFQUgz5K_lyxWyVM2-oUQwQBpgFY5lTkM4Pl9Rq1FPEnUxK_J9LNlPOg9KFVVN_pGqw=w1280-h960-no
zrbbPN_zmT_s56SbW1Sud-Z9Fwx0QIv2eaIXHByN_AOb2wAFxZYjN3452D4z_Kn9DptDH1MoyW7fEHWwlW5LkUDNRY0_zSLzlNgWrfRoq3Dvn6tdvNlEL4nBMwrVHx-V4BKpkdkC2NCLoAfwHxfRVoxLZgcWG-T99t9V9JSaplrhbXgpbFv92NU7BdirAkBam0na6Nq7M868v1nC47dAMXkGg33KVbCgmXoyY7yeFMnpMntFQexJdvstLIHsO2RgpZm9w7WK2R7IMsKkz41lJcZD9Ot7-6OPnCMcoHP86Ke-HFbbinQ7EKFX_L5gAySA7F7MgXKdDfoNeQLxTygi_k9MbqmooXmHjXSjZEY8feK7p1xviZFPJIdHOtbTA71vRd71lE4HZjQcYuKCxrIdvlEcIoa0RzWE5dfSyj2WDCRV8V4N8cmFxvtDRhQ28FuV-DYXLLJ-AUijdKsIaeQI0L94bMwbG8ZA0o51X_Kdy1aWAiAAQ8TrwjIdlLSr6N2tQMeTv11j6AVOTnkPht4c0IdRciZxlFlsP4iGDrYn5FTPuYzFsrBzwZyMJztiMMFgiho38riDRp_hQXrj-xL_oVkxct7vvAEvFJU7mT4CIA8lCBF9=w1280-h960-no
61iH7tx5v72YzmuQoP1ANU9JgOgd-rSFXy_085AeMBhk3hLA6CTXG03ZHQrEKwD-e6KQsdBac9Mk_uxnoioOkKgihmx9M0DTE_16d3xBNjQWmzwEPIAx3CuIUsg0FA82eCldq9aSWXmgtXj14pc4yelaufwAZqL9Yyj7DKho9zgT0IWxLRwq48oovl3d-iDvoCRGBB9QnDYLMEDe9qO7VkupQ4fZ2KLeSqxAbOk_oMvWmrRNKdoz_g5wLrxS9RMRU0y2FL7Xa2pdJKrsi2Vn6MyQRjR-sX1wHerxBrf-omIbdTedPX8-1mF5YiSV5mOKobJ3gV9Rx8ufpTe71mxsfOHvZzW2WUlZlFKnVD7trNl0DZTlmzGq-AaQFTtdpnwoRslSRkH8d487x7dfIRz4X-DHXH9S62sH7RbcfTFddLZLMi0KWC7t8BBCbl_9K__NxcXXtIprbD-jkVsU-SMN9JBiebMZUdusMipD1jIqWl0pBlvL4jhExcQFg2eqwP0R3JgUe9hP82auisCQZkhdWDzZbsp7sYELn97dfsfTPTcxefdJwd5r88LnHsVSLTrz4WfkLJvFXchkg3UsYDZWkUsdSrTqrg9YiPi02ue3xAZhQNDl=w1280-h960-no
New trailing arm pocket from inside the car
