i will start pasting the text that appeared in the last CSL UK newsletter, thanks to John Renaudon
Rear Sub Frame Bushes.
I had a member contact me about changing the two bushes between the rear suspension sub-frame and the body shell.
In theory it should not be too difficult but you need plenty of good fortune. Get the rear of the car on axle stands, remove the rear wheels and put a trolley jack under the side of the sub frame you are going to tackle first. Undo the two bolts holding the bush steadying arm to the body shell and then undo the central nut holding the steadying arm to the bush. Remove the steady arm and then loosely replace the nut (to protect the thread of the bolt as you have to use a small club hammer [copper headed if you have one] to then to drive the bolt through the centre of the bush up into the car under the rear seat. If you are lucky the bolt will NOT be rusted into the bush.
Head of bolt which is fitted from inside the car under the rear seat
Special long bolt
Sub frame bolts (+ two the other side)
Central Nut
Now you can undo the four bolts holding the bush to the sub frame. Again if you are lucky these bolts will not be rusted into the sub frame. With these 4 bolts removed the bush should fall into the palm of your hand with the sub frame supported by the jack.
I was able to do this on my 2002Tii some years ago but I had fitted the bush to the sub frame and body shell with anti-seize grease on all the bolts when I had assembled it. Reassembly is the reverse and you have to drive the centre bolt back down into its splined housing with the club hammer before fitting the new bush and then refitting the four bolts etc.
The trolley jack just ensures the sub frame does not sag down too far when the end is not fixed to the car.
If the centre bolts are rusted then it can take quite a bit of force to get them up into the car. Once out it would be worth getting new ones because the thread will be damaged. If the
four bolts holding the bush onto the sub frame are rusted then you can cut off the bolt heads with an angle grinder and hope to prize off the old bush before driving out the remains of the bolts - but you will see they go through the full width of the sub frame which is quite a long tube to be rusted into and you need all four to be free.
If you have any doubts then it is probably better to get your local garage to do the work as they can drop the sub-frame at both ends on a hoist and get better access to the four nuts and bolts holding the bush to the sub frame (and possibly use a bit of heat) and/or the centre bolts.
Try one of the bush to sub frame nuts/bolts first as this will give you an idea about the state of the set before you start on the big central bolt. If it is really rusted in, replace it and head for your local garage –it does not need an E9 specialist.
Special long bolt
Central Nut
