1973 E9 Interior Foam
pickman
South Haven Michigan
I have two pieces of formed foam a large and a small piece not sure which one goes LH to RH are these still used? They are not in the best shape but still usable I think.
michelk
netherlands
hello
these are for under carpet by feet/shoes
the little left and the biggest right
this are for a comfort position
dave v. in nc
North Carolina, USA
Might check the search, as there are some discussions...but I assume you mean the footwell pieces...small goes left of the pedals, large on the pass side. Yes they are still used; otherwise carpet pieces wont fit. Some folk have used spray foam (like "Good Stuff", etc) and then put plywood on top to make the flat plane for the carpet to rest. In theory, they help with sound/heat insulation...
pickman
Attached photos of the reworked foam pieces used fiberglass to reinforce thanks for the help.
  • Front Foam.pdf
michelk
netherlands
hello
what are you want exactly know about the two pieces foam ?
you want 2 new ones ?
DWMBMW
Miami, Florida
Divers side is a dead pedal for your left foot.
Cornishman
Essex, UK
Does anyone know if the RHD also has these? Mine doesn’t not, but that does not mean much.
