74 Window Mechanics
JayWltrs
Oklahoma City
Front and rear passenger windows finally gave up the ghost. As noted in the primary window write-ups by others, the procedure for swapping to E28 motors isn't as complicated in the 74. But the regulator is very different. A couple of questions/observations:
1. I don't see bump-stop screws or their mounting tabs on the regulator like on the early E9 or E28 regulators. There is a white plastic disc that looks like it might serve a similar function. Is this correct or have they just disappeared and I need to find a place for them (found nuts, washers & horsehair in the door, but no stops)? Some pics (will add backside pic later):
2. The tracks/guides have the hardened molasses, which was pretty easy to clean on the regulator once removed. But I'm hesitant to remove the tacks because I'm not sure I'll ever get them back in correctly, and I'm worried about destroying the already damaged flat-head screw/bolt. Not to mention that it will significantly expand the scope of work for 4 windows if I have to remove the upper trim to get them out. Buck up or clean them in place?
Gary Knox
West Chester, Pennsylvania
Jay,
Those rubber bump stops should be there. Time to install new ones! I was able to clean my door mechanism and tracks fairly well 'in situ' by using quite a bit of Brake Cleaner spray (lots of paper towels in the bottom of the door to absorb the gunk and cleaner), then applying some SuperLube in the appropriate places. I removed the rear window mechanism to clean it. The cleaning and the e28 motors took the time for either up or down from about 20 seconds to 6 seconds for either F or R windows.
Gary-
JayWltrs
Oklahoma City
Jay,
Gary-
Thanks, Gary. I'm going to take the cover over off the driver's side and compare to make sure I'm not crazy or missing something obvious. I have the SuprerLube ready to go! I dont't use brake cleaner as much anymore. It took barely 10 mins to clean the gears and regulator with careful use of PSC 1000 in the parts washer and a nylon brush. It's my new favorite stuff at $50 for 5 gals at Tractor Supply--not as toxic, noxious smelling, or expensive as the hard core stuff, but it works amazingly. That's one reason I would like to remove the tracks. I can clean them 10x faster and better if I can remove them--just doubting myself as to whether I can get them back in correctly.
JayWltrs
Oklahoma City
Front windows don’t have the same stops:
The flat plate was covered with a foam pad that holds moisture and was the only part with rust. Not sure what type of pad I’ll replace it with after paint, but it won’t be a sponge.
JayWltrs
Oklahoma City
The baked molasses gummed up and froze the track wheels—I was afraid they weren’t salvageable. Required lots of patience, fluid, soaking, brushing, dental floss, multiple passes, etc.
bavbob
Boston, Ma
This raises the question I have concerning lube on the front (manual) windows. The bearing unit needs to be greased but why the track? Seems to create a lot of problems later. My slide so nicely after cleaning all that molasses off and just lubing the bearings.
BTW there was a post a while back with an image of a spring and asking what the spring went to . Those two cups on that unit are supposed to be flipped to face each other and have the spring in between them.
JayWltrs
Oklahoma City
I think this is an excellent idea and will try before closing. Might at least need some dry teflon spray on the tracks to protect the bearing surface. Cleaning the hardened stuff is bad, but probably easier than finding replacement bearings.
Missed the spring post. I'd have never figured it out had it not been there. I couldn't really see the plastic cups until I'd removed the 2nd or 3rd layer of goop. Then I thought the cups were a single broken part, until I freed it up some more and the lights came on as the spring popped out.
The 74 motor deserves some torque respect for raising and lowering the windows at all this last year through what's essentially glue.
