A/C parts
OZCSi
Hi, looking for the evaporator for an E9 Air Con console assembly , it has the cooling part that recives the air con lines from the engine bay and the fan and housing. I have all other parts I need under control, just need the evaporator.
Looking for the a/c guys here to tell me what interchanges as well, so speak up and help it hit 100F here in oz for the first time this summer!!
Thanks in advance
OZ
oldcoupe
E9 Aircon
I used the unit from an E3 - I believe it's the same as the one used in the CS. The mounting bracket that sits on the tunnel needed to be slightly altered to get clearance.
If the car is RHD, you need to be put a lot of thought into getting the pipes through the bulkhead, around the pedals and onto the unit.
From memory, the E28 unit might be the same also- check the realoem list and applications.
OZCSi
Thanks for the info, I have also heard there is a few type that were either semi factory or dealer fitted, the behr brand unit keeps coming up?
Cheers
