Ac relay replacements.
bimoverde
california
From my diagram and some of the discussion on this board. There are 2 important relays connected to the ac blower motor and the compressor. One is by the fuse box(bosch 0332100020) and one under the coil(i have now a weber 20210 100A in place.. not sure if it is the correct 4 prong relays needed)
Can someone tell me if both relays should be the same ? What is an appropriate relays to replace the bosch one by the fuse box(i don't think original new ones are available).?
HB Chris
Huntington Beach, CA
The one near fuse box is a changeover relay used in 73 and earlier coupes only, if you have a 74 you don't need one.
the original Hella relay for the condensor fan is a 91/6 24 12V with ears on the sides of the can so it can be screwed onto the inner fender.
I find them on eBay occasionally but you can use any new standard 4 prong Hella or Bosch relay with the 85, 86, 87 and 30 tabs. Avoid the chinese junk ones.
bimoverde
california
what is a good relay replacement for the relay by the fuse box(it shuts of the fan when the ac blower is on)
original is bosch 0332100020
sfdon
sfbay area
I believe The relay under the fuse is very different from most relays. It opens the contacts when energized.
