Aluminum parts finishing techniques.
Nicad
Toronto
I know there are many techniques people use when refinishing their alloy parts . I have experimented with a few. So far I like the look of bead blasted and Alodyne treated parts, as I find it looks natural. Not sure how it holds up in use though. I see vapour blasting seems very popular as well in motorcycle restoration circles. I have also done a few parts in clear powder after bead blasting, but durability with my DIY powder coating has been hit and miss. I guess other options are tumbling the parts in an abrasive vibrator, etc. What would the BMW museum do for things like valve covers, intake manifolds, etc? Is there a new technique that has impressed you as being superior in looks and durability?
HB Chris
Huntington Beach, CA
The BMW museum would not do it correctly just cheaply. I now love vapor honing (blasting) followed by clear matte ceramic from Cerakote. In the past I would have them tumbled but cleaning out residual media is a pain and vapor process is cheaper as well.
mark99
Kirkland WA
vapor blasting still has media to clean, important with things like a valve cover
mark99
Kirkland WA
just saying, it uses (I believe) glass beads also, so important to get them out where they might get into the oil
I have not had any parts vapor blasted, but have tried just about everything else
Markos
Seattle, WA
I have had really good luck with vapor blasting aluminum bits. Agreed that media
is left behind. Crushed bead.
I’m having my dogleg and LSD dry ice blasted this summer (see vid). Dry ice because I don’t want media inside the case. Even then I am worried about driving scale or debris intothe seals. I intend to protect with moldable plastic (see vid).
My only complaint is they are all mobile units. I want to do the undercarriage but I don’t want a bunch of gunk in my driveway.
Dry ice blasting:
Protect seals with moldable plastic:
mark99
Kirkland WA
Dry ice blasting:
I might have to order some of that Polydoh to play with!
Markos
Seattle, WA
Never use media on a tranny, bad things can happen.
I know the use case which you speak of, and also discussed with said expert on this subject. :)
Dry ice isn’t media. It is frozen carbon dioxide and it evaporates on impact. They use dry ice blasting to clean food manufacturing equipment and smoke damage from fragile books.
Nicad
Toronto
I bead blasted my Diff. To protect it I used a hot glue gun to seal it first. In retrospect I do think it is risky and probably wouldn't do it again. That dry ice blasting did a great job.
Cornishman
Essex, UK
When I was considered getting my rocker cover / valve cover media blasted the guy said that we needed to make a strong jig to bolt it to with a large rubber gasket seal. This was really a piece of 3/4 inch ply, with a rubber membrane, then the rocker cover bolted to it. The aim, keep out of the media from inside. An alternative was to drill out the rivets that hold on the internal breather cover, thereby allowing it to be cleaned afterwards.
I decided to against doing anything, think it is one of those things where everything or nothing needs the great finish.
mark99
Kirkland WA
If you have engine block work done, to clean it they put it in an industrial 'dishwasher' the idea is that there will be metal filings, and there is a method to cleaning
When I did my valve cover, I removed the little cover inside, after media blasting I had the machinist clean it in the industrial washer
I taped the holes where the rivets came out and put machine screws in with permanent Loctite
Gary Knox
E9 Member Emeritus
West Chester, Pennsylvania
To see more about dry ice blasting/cleaning, click on this link from one of my other car forums: https://rennlist.com/forums/928-for...mple-that-didn-t-require-a-restoration-2.html
Some pictures of a Porsche 928 undercarriage after and before cleaning. BUT - scroll down to post #20 and click on the YouTube recording to see it in progress. Impressive. On the other hand, it reportedly took 20 hours to clean the underside and engine compartment (engine out). At $250 per hour, you gotta' really like seeing the underside of your car (in a mirror, or on a rotisserie) - OR have a reasonably large checking account!! - ha.
Markos
Seattle, WA
OMG! :p
Talked to Griots in Tacoma. They want around $100 or $120 an hour. They said an undercarriage can take about 14 hours.
tmh
Naples, FL
Wow, amazing. At $3000 it would worthwhile. There are some skill and abilities on display.
Dick Steinkamp
Bellingham, WA
Very satisfying to watch. :cool:
That undercarriage still had original paint/undercoating in good condition. I wonder what the "after" pics look like on 50 year old cars.
bmw2800cs
San Jose, California
Mindblowing, I'm hearing more and more about this, never seen it done. As Dick said, it would be great to see what an older car looks like. As an aside, I noticed they removed some spray paint, this may be the way to fix the black e9 that everyone is harping on - the one with all the spray paint in the engine bay and underbody.
