Date Departs/
arrives Route Flight/
operated by Travelers Frequent Flyer1
Sun,
Jul 20 8:33 a.m.
1:26 p.m. LONG BEACH, CA (LGB) to
AUSTIN, TX (AUS) 1416
Thanks for the info on the car. I saw it come up and figured it might be a desirable engine/trans for the future of my underpowered coupe. I'm going to put a new set of Webers on her since I'm having lots of problems with the ones that came on the car.
Austin is competing with Dante's 8th ring of hell for heat! We did get some rain but never enough.
Don, after I have everything sorted out I'm going to drive her to your shop for an engine and rear-end swap
Also, still having a little problem with the rear of the car- despite replacing everything, and I mean everything I still get an exaggerated "dipping" feeling when I take hard right turns at moderate speed. Left turns are very smooth and stiff. Has anyone experienced defective shocks, or possibly weak springs from Bilstein or Carl? Not bashing either, but sometimes things happen in manufacturing.
Could the rear alignment create this sensation, I welded in IE's toe/camber adjusters and the shop that did the work may have screwed up. Not bashing them either but sometimes things happen.
