Hi guys,
Im currently in the process of a bare metal rebuild. Im curious what peoples thoughts are on the original construction of the bulkhead/strut tower area.
This is the area in question:
The example above is one of the nicer examples that I have seen. Which is hilarious, because the original composition looks so poorly constructed, like a bunch of offcuts were just spot welded together at the last minute.. Seeing examples with original seam sealer/sound insulation etc smeared all over look even worse: (no offence, I'm just talking about the original design, not these clean examples in particular)
Here are a couple more examples showing the metal construction
QUESTION ONE:
I know people go to extreme lengths to recreate their cars as original as possible, but what do people think about rebuilding this area cleaner such as the example below? Of course I think most will agree it looks much cleaner, but will this type of thing hurt the value of the car, or would it be beneficial to the cars value?
Or do people want to see the outlines of that original sheet metal, and not suspect its smeared with bondo.. ?
What are your thoughts on sound insulation/seam sealer etc?
I have actually purchased replacement sheet metal already with plans to recreate it as per the first couple of pictures I posted, but after seeing the example above I've been thinking of cleaner options. Just don't want to hurt the value of the car... Thoughts?
QUESTION TWO:
My coupe had hood pins fitted when I purchased it, but in the wrong location. I would like to replace them with some new ones in the corner of the hood as the CSL's had.
I have a couple of pictures here showing different styles on different coupes. I appreciate I probably can't buy original ones anywhere, but I'd like something close.
So anyone with hood pins, could you please share a picture or any measurements you have so I can get some as close looking to original as possible?
Many thanks!
QUESTION ONE:
QUESTION TWO:
Many thanks!
