Calipers...
Bavman
Have noticed some posts for 6 series calipers...what is the advantage? I have some I would sell, front and rear, also some euro 7 series fronts with only one line, the advantage there is you can use more modern master cyl...
Tested, currently in use calipers $75 ea
Used calipers that you may get lucky on but best considered cores $40 ea.
Personally I am going single line on one of my Bavaria’s as the cost of a new master is much less for e30 or e28...
If you need any parts, caliper halves, pistons, spacers I can help with that also.
The only way to possibly reach me is 324tdi@gmail.com
Alonzo Taylor
Markos
Parts Mule
Staff member
Seattle, WA
The early e24 rotors have a diameter of 280mm vs 272mm. Both are 22mm thick. The caliper itself is slightly longer. If you measure the opening across the top you will see that it is slightly longer than an e9.
Also, the M535i has 25mm rotors.
early e24 caliper...
