decoupe
(deceased)
It would appear that my centre bearing carrier on the driveshaft has been installed backwards which may be linked to mild vibration - noticeable at low speeds when both in gear and out of gear.
http://i54.photobucket.com/albums/g120/decoupe/IMG_1256_zpstkw5gtzt.jpg
The manual clearly shows the open face of the carrier should face the front. The manual says to remove the circle and dust cap and press the bearing out. The bearing itself is fine. A new unit with the bearing is pretty cheap but I still have to get it off the driveshaft.
How exactly do you support the bearing in order to press the splined shaft through without damaging the driveshaft and trashing the unit?
