Chrome Rear Window exterior sill
Discussion in 'Parts' started by 79aggie, Jan 28, 2019.
  1. 79aggie
    79aggie Member
    60
    3
    8
    Dunn Loring (Washington D.C.)
    Anybody know the part number of the exterior rear window sills? The ones that swoop up as the hokey stick.
    I v'e looked everywhere on the RealOEM site and can't seem to find them.
    I would consider buying a set if any one has them.
  2. Keshav
    Keshav Well-Known Member Site Donor
    1,319
    718
    113
    Weiterstadt, Germany
  3. Markos
    Markos Rust Staff Member Site Donor $$
    View My Showcase
    8,036
    2,127
    113
    Seattle, WA
    I have a spare set. Are you looking for better chrome or are yours missing?
  4. 79aggie
    79aggie Member
    60
    3
    8
    Well better chrome would be a plus, but not necessary.
  5. Stan
    Stan Well-Known Member Site Donor
    View My Showcase
    5,503
    473
    83
    Newmarket, New Hampshire
    I will have a set that needs re chrome soon
    Not sure of price
  6. 79aggie
    79aggie Member
    60
    3
    8
    Keshav likes this.
  7. 79aggie
    79aggie Member
    60
    3
    8
    Can you post or send me a picture of what you have?
  8. Thomas76
    Thomas76 Member Site Donor
    109
    24
    18
    Michigan, USA
    @79aggie FYI you can't buy the felt/metal strip that rivets to these anymore, the rubber is available but you need to get creative with the other. I'm currently digging for a solution.
    Mal CSL 3.0 likes this.
  9. Ajay
    Ajay Member Site Donor
    78
    41
    18
    Irvine, CA
    Thomas76 likes this.
  10. Ajay
    78
    41
    18
    Irvine, CA
    Check the picture under the vent window.
  11. Stan
    View My Showcase
    5,503
    473
    83
    You could try coupe king
  12. Thomas76
    109
    24
    18
    Michigan, USA
    @Stan have you tried their suggested replacement?
  13. dave v. in nc
    dave v. in nc Well-Known Member Site Donor
    1,426
    113
    63
    North Carolina, USA
    PM sent to 79aggie...
  14. bert35csi
    bert35csi Well-Known Member Site Donor
    1,350
    63
    48
    san francisco
    The 07256D69-E12C-4FAB-B86F-43577A4BB169.jpeg Likely part # 6. L- 51367740123 and R-51367740124.
  15. 79aggie
    79aggie Member
    60
    3
    8
    Yea, I know but, my felt and rubber are in good shape, thanks.
  16. Stan
    View My Showcase
    5,503
    473
    83
  17. Keshav
    1,319
    718
    113
  18. Markos
    View My Showcase
    8,036
    2,127
    113
    Seattle, WA
    Sure, it probably won’t happen until the weekend though.
  19. Tony.dreamer
    Tony.dreamer Super Active member and parts collector Site Donor
    671
    128
    43
    Edmond , Oklahoma
    Be aware that this piece has been customized to fit for each individual E9 at the factory. Incidently this fact made me love the hand made E9 even more! It is very likely that a Replacment piece from another car may be slightly too big or shorter the end of the piece to the back of the car.
    As you know it is a solid brass core chromed piece!
    My advise is to fit it to the car first before you send it for chroming! The tail end of the piece meets the bottom of the drip rail and if the replacement (donor) piece happen to be too long it can be filed the edge and fitted before you send it for Re-chroming ! Also there is small screw that secure the front of the piece to the body. make sure you place the screw in it. It is at the front where it mounts to the car! Re-chroming can fill up , or cover the small screw hole! W&N sells the curved (hockey shape) interior rubber ! The felt can be made from available glass shop squeegee felt and riveted very closely as original.
    The lower u Channel rubber(3mm tall) that sits between the piece and the painted body is also available from both BMW as well as W&N sold by the meter . Make sure to cut this rubber piece slightly longer as it shrinks a bet. You can always cut it shorter if after few months of it sitting on the car if need be. Remind the body shop not to pull or stretch the rubber when they install it...
    Best wishes !
  20. Keshav
    1,319
    718
    113
    With all due respect Tony, I find that very hard to believe. But with your big collection of E9’s, I won’t get into a arguement with you ;)
    Regards
    Keshav
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
