Inner Screw
If we tighten the inner screw independently of the outer screw (meaning we don't allow the outer screw to turn with respect to the body of the MPS as we turn the inner screw), the armature is driven out of the coil, reducing the inductive coupling, causing the ECU to shorten the injection pulse. This adjustment will make the mixture leaner across both part-load and full-load, because the inner screw is directly coupled to the full-load diaphragm. Similarly, loosening the inner screw independently of the outer screw moves the armature into the coil, lengthening the pulse, and enriching the mixture across both part and full-load.
Outer Screw
Under part-load conditions, the bottom of the outer screw is held against the part-load stop by the pressure differential across the diaphragm. If we tighten the outer screw independently of the inner screw (meaning we prevent the inner screw from turning with respect to the body of the MPS), the middle of the diaphragm is moved away from the part-load stop, decreasing its throw, and decreasing the amount of enrichment under full-load operation. Additionally, tightening the outer screw independently of the inner screw has the same effect on part-load operation as loosening the inner screw, enriching the part-load mixture.
Similarly, loosening the outer screw independently of the inner screw moves the diaphragm towards the part-load stop (note: in the condition I'm describing here, the MPS is under part-load pressure, and the bottom of the outer screw is in contact with the part-load stop plate), increasing the throw of the diaphragm, resulting in a larger degree of enrichment under full-load operation. Also, the effect on the inner screw is the same as if it were tightened, leaning out the part-load mixture.
However, if the outer and inner screws are "coupled" and the inner screw is turned the same amount as the outer screw, then the part-load mixture adjustment is unaffected, and the effect on the full-load mixture is the same as described above. This behavior will be exploited in describing how to properly adjust the MPS.
Full-Load Stop
The full-load stop adjusts the maximum movement of the diaphragm. Once the diaphragm engages the full-load stop, if the pressure increases further in the MPS, the mixture will continue to be richened, but at a rate determined by the expansion of the aneroid cells and not by the movement of the full-load diaphragm. Note that if the full-load stop is adjusted so that it does not make contact with the diaphragm under full-load conditions, the diaphragm will be unsupported. This over-stresses the diaphragm near the flange and leads to early failure. Most MPS's are adjusted so that the vacuum level where the full-load stop is engaged is about 2 in. Hg below atmospheric pressure, though I have seen some that were adjusted to 4 in. Hg. Note that at high engine speeds, due to the pumping restrictions of the intake, even with wide-open-throttle the intake manifold is about 1 in. Hg below atmospheric pressure.
Coil Spring
While this is not an adjustment that can be made on a specific MPS, the spring constant of the coil spring sets the vacuum level where the onset of movement of the diaphragm begins (Po). Bosch employed at least two different types of coil springs in the MPS's used with 914 applications that gave different values of Po. Units with the different coil springs can be identified by "short" and "long" coil spring holders in the main casting of the MPS. As mentioned above, the "short" coil spring units have a Po of about 6 in. Hg, and the "long" units have a Po of about 8 in. Hg (based on a very limited sample).
