gwittman
I replaced the differential drive flange seal about 2 years ago and it is still working well. However, I have discovered there is a leak coming out of the center of the drive flange where the nut is.
I have studied the Blue Book extensively and can find no reference of a seal for the collar nut area in the drive flange. If I am over looking something please let me know. My plan at the moment is to remove the nut, clean every thing there very well and use a liquid sealant on the collar nut face and first few inner threads. I have used SealAll on the lower bolts of a float bowl of a Holley carburetor with good results. These bolts are wetted with gasoline and if it will seal gasoline, it should seal gear lube.
I have a crush sleeve but plan to just use the nut/flange position marking method and re-tighten to the same position and verify drive torque value.
I am open to any other suggestions.
