gwittman
I replaced the differential input shaft seal using the BMW method 'without replacing the crush sleeve'. I resolved the minor leak but am a little concerned about my work. I ended up rotating the nut about 5-10 degrees farther than the original position and still did not quite get to the specified torque. I decided to go ahead and assemble everything to see how it works.
There are no unusual noises and the force to rotate is about the same as it was before. What I do find is after driving around town (stop and go) for about 10 miles at under 50 mph and moderate acceleration, the differential is near hot. When I put my hand on it I can keep it there but it is near the point I would have to pull it away. I am guessing the temperature is around 150 to 160 F. That seems a little warm to me. Does anyone think that is normal? I have ordered a crush sleeve but would prefer not going through all that trouble needlessly.
