E28 driveshaft for my E3 with a 265 Getrag
Discussion in 'E3 General Discussion' started by Mike Goble, Jun 14, 2017.
  1. Mike Goble
    Mike Goble Active Member
    View My Garage
    821
    76
    28
    Fairfield, CA
    I posted some pics yesterday comparing the driveshaft from a 5-speed E28 to the driveshaft currently in my E3 here:
    http://www.e9coupe.com/forum/threads/what-did-you-do-to-your-e3-today.25126/page-2
    I put it in early this morning and it was an easy process. I made a couple of adapting brackets from some 1" angle iron and bolted it up and used a later guibo. The test drive was smooth as butter, gone is the low speed shudder when you're accelerating in first gear.
    The adapter:
    [​IMG]
    The guibo:
    [​IMG]
    Joe Barthlow, GolfBavaria and restart like this.
  2. Joe Barthlow
    Joe Barthlow Member Site Donor
    154
    24
    18
    Eugene, Oregon USA
  3. adrian
    adrian New Member
    3
    0
    1
    Maynard, MA
    So a CSB requires virtually no vertical (gravity, etc) support...? Doesn't "feel" right to me (just eye-balling that set-up) but if it worked, then...good to know, thanks!
  4. Mike Goble
    View My Garage
    821
    76
    28
    Fairfield, CA
    If the driveline is straight and balanced there isn't very much leverage on the bearing. The bearing proper is in a fairly flimsy rubber outer mount, so it doesn't take much to deflect it no matter how sturdy the mount. Earlier this week I drove the 450 miles down I-5 to my son's house at speeds of 85-90 mph and it was smooth as silk.
    Joe Barthlow likes this.
  5. 73tiiguy
    73tiiguy Member
    34
    3
    8
    Hey Mike, I saw some other posts in regards to your 3.5 motor using dcoe's. About how much power you think you're getting from that setup? I'm thinking about moving to an m30b35, but wanted to use the l-jet logs, along with l-jet electronics but with slightly updated injectors. Was back-dating the b35 ignition difficult? Was thinking it was a fairly simple job of stripping all the motronic hardware off (upper timing cover, and cam gear), then install early cam gear with the distributor drive. Or would a complete camshaft swap be needed as well?
    Thanks in advance!
  6. 73tiiguy
    73tiiguy Member
    34
    3
    8
    Ok I just figured out that all of the cams are different between carb/l-jet/motronic.
  7. Mike Goble
    View My Garage
    821
    76
    28
    Fairfield, CA
    They're DGV's with the choke wired open. I don't have a good guess on the power, it's an $80 motor that runs very well, and the torque is a significant improvement over the 3.0. On the 3.5l I used camshaft adapter nut 11311284801 along with the stock distributor drive and cover from the 3.0 and retained the stock B35 cam. I use the points to trigger an MSD ignition system, and it has worked very well for years.
  8. 73tiiguy
    73tiiguy Member
    34
    3
    8
    Thanks, I see - so the dizzy drive fits into that slot in the special nut. That's nice.
    Hey, I'm just down the road in Concord if you ever have some time to meet up let me know. George
Share This Page
