windnsea
What is the proper sequence for installing the beltline trim (flexible rubber/plastic followed by the polished aluminum piece) for the front fender on an E3? I know that the rubber piece is laid down first and then the metallic piece over/into it, but what is the 'sequence' for the plastic and the one or two small retention plates that tightly hold the metallic beltline piece is it one at each end or two at the front? The metallic retention pieces (51131817064} are fastened from inside the fender with washer and a nut while all the plastic pieces are mounted and then expanded in their holes by pushing in the center piece. Do you use the metallic retention pieces one at each end or both on the curving front section of the trim??
Getting my 1971 E3 Dietel Alpina back in the road 'slowly' !
