I was working on the Chamonix project and bumped a fuse with a wrench which caused a small spark. No fuses burned, all wires fine, no wires disconnected from back of the fuse holder/junction block. Now I only have less than 4 volts from the battery on the large red wire (all red ones from the battery) inside the cabin that goes to the junction block and continues to the ignition switch. Nothing works or lights up, everything was working before so now I can’t start the car or do anything. Battery is new and fine with 12.3 volt. Very strange and very disconcerting as wiring is one of those issues we deal with on a coupe but are nightmare to identify and resolve. And all I was doing was removing extraneous wires that were tapped into the existing harness that every coupe seems to have!
On a side note, I have a brown ground wire that goes from rear fog switch (not present) to the wiper relay to the load shed relay and into the harness bundle and includes the turn/hazard relay that is fried so it obviously shorted to a hot wire somewhere and melted all along its length. Almost everything in the dash shares at some point a common brown ground wire. This one is going to be a challenge as it is so hard to open up the harness while in the dash, wish me luck. I think I will look for continuity in every positive wire to see which one was shorted out.
Can you tell I hate working under the dash?
