Fender side grills- posts break.
Discussion in 'E9 Projects and Restorations' started by m5bb, Feb 9, 2019.
  1. m5bb
    m5bb Well-Known Member Site Donor $
    View My Showcase
    1,446
    204
    63
    Peachtree Corners, GA
    Here's a problem I encountered that some others may find as well.
    The crappy plastic fender grills.
    When removed 3 years ago, the posts break off. BMW uses a rubber donut shapped washer that pushes on the post that goes through the metal fender and that holds the grill on the car.
    So 2 relatively new grills were trash.
    I thought about this and remembered my model train days when I would buy brass tubing from the hobby store. I had some around and was lucky I had the correct size to push on the posts and make them long enough to have some post on the inside of the fender to attach the rubber washers to. NOT, the BMW rubber washers have a spring steel disk inside them with the one-way teeth.
    Push it on and it ain't coming off. That's why the posts break. I tried to drill the metal disk hole to a bigger size but the spring steel does not drill easily and the one way teeth catch on the drill bit and then it tares out of the rubber washer.
    So once I got the brass rod on there, it was how was I going to hold them on. How about a washer and a tiny rubber o-ring. It took a good deal of effort to get this o-ring on the post so I am pretty confident it will stay. I will monitor after some miles.
    I thought about putting threaded rod in the grills but was afraid they would break.
    So here's a couple photos to explain this too complicated explanation. As a career photographer a photo is worth a 1000 words. Enough said.
    teahead and adawil2002 like this.
  2. mr bump
    mr bump Active Member
    570
    84
    28
    nottingham, UK
    Brilliant idea!! I tried to remove one of mine, after one small post broke I gave up as it's an impossible task to remove them posts intact.
  3. Stevehose
    Stevehose Well-Known Member Site Donor $
    View My Showcase
    8,788
    1,183
    113
    New Orleans, LA
    Looks great Gary, I used silicone vacuum tubing to hold mine on, seems to have held up
    adawil2002 likes this.
  4. mr bump
    570
    84
    28
    nottingham, UK
    How do you mean Steve?
  5. Markos
    Markos Rust Staff Member Site Donor $$
    View My Showcase
    8,036
    2,127
    113
    Seattle, WA
    You can also use heat shrink.
    m5bb likes this.
  6. m5bb
    View My Showcase
    1,446
    204
    63
    Good idea Steve, I knew there would be some other solutions.
  7. m5bb
    View My Showcase
    1,446
    204
    63
    Like this one too.
    In fact I could go put some heat shrink on in addition to the o-rings. Excellent!!!!
  8. Stevehose
    View My Showcase
    8,788
    1,183
    113
    New Orleans, LA
    Put grills on fender, then push on silicon vacuum tube from behind to hold in place. Allows for removal without trashing the posts.
    mr bump likes this.
  9. eriknetherlands
    eriknetherlands Active Member
    609
    225
    43
    Netherlands, Eindhoven area
    I like the vacuum tube idea.
    Could you not also cut a thread on the posts? I know they are plastic, but on some plastics it will work.
  10. m5bb
    View My Showcase
    1,446
    204
    63
    There's not enough post left if yours have broken off like mine did. Cutting those off and threading a new post was the next option.
    I looked at that idea and it is feasible. Rods would be pretty small and threading them into the grills a little delicate but certainly doable.
    A decent drill press would be mandatory to drill for the tap and there's not much depth there to thread in to. And unfortunately most taps are tapered so have good threads very deep in the grill body would also be difficult. Do they make flat/square bottom taps?
  11. bfeng
    bfeng Well-Known Member Site Donor
    1,801
    359
    83
    Massachusetts, metrowest
    Yes and it is often easiest to go to depth with the tapered tap and the finish with the square profile tap. Trying to do a deep hole with the straight sides tap is often a recipe for disaster.
  12. restart
    restart Well-Known Member
    1,057
    134
    63
    KANADA, Roberts Creek, BC
    How about 3m or similar tape made for this type of attachment?
    Remove with dental floss.
  13. Lotuss7
    Lotuss7 Member Site Donor
    387
    5
    18
    SF Bay Area
  14. eriknetherlands
    609
    225
    43
    True when talking about hard steels; taps can snap. Here in plastic I would be worried not for the tap but for the plastic post breaking. Hence I would use the taps that come in three stages; coarse, middle & fine and then finish with a flat top tap (do they translate to "Blind hole taps"? ).
  15. m5bb
    View My Showcase
    1,446
    204
    63
    Do you mean drill bits and start small then work up to the size needed for the tap?
  16. eriknetherlands
    609
    225
    43
    Mb55, I meant using 3 different taps. see the picture enclosed. it shows an m6 tap set. Right one of the 3 short M6 taps is the start=coarse. Middle is fine. Left is finishing tap. The longer one is intended for blind holes, it cuts an accurate thread in a blind hole up to 6 mm from the bottom of the hole. But anyway scrap the idea to use taps; I wouldn't go that route: I just measured the pins on my NOS side grille and they are just 4 mm. It kinda kills my own idea; to drill a 1,6 mm hole in a 4 mm pin nicely centered and straight is really difficult, then tap a M2 thread in them, (needing likely an investment in an M2 tap set) leaving only a 1 mm thin cylinder with female thread. It is becoming quite an effort, and so delicate that I would fear to end up with a broken pin.
    Oh, and don't forget your working on a delicate, mirror finished piece of plastic.
    I think i'd either use the original snap rings (or generic of the shelf ones, they're standard industry items) and just cut them in half with pliers if I ever want to take them off and replace with new.
    Or i'd dive into cutting an M4 thread from the pin and use a plastic m4 nut with rubber washer on the inside of the fender. An M4 nut is also way easier to install inside the fender then a tiny M2 screw is.
    I just also looked (for the first time) at the attachment of the grilles on my car; they just got rusted cross headed screws all the way through, splitting the bars in two..... I knew the chrome looked horrible from 10 feet away but never realized they were already broken.
    You see, there is always a good reason to go for that elusive NOS part when it comes by....
    O how I whish someone would CNC these out of steel or aluminium....(I know it has been done, I've seen a thread here on it somewhere, but it was a one-off)
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
