All Sold: 1971 2800CS Part Out
Markos
Seattle, WA
Front trim sold. Rear interior door jamb trim still for sale. The rear has the half circle cutouts. Typically scraped up by the seatbelt.
Markos
Seattle, WA
Sold:
Motor/Trans
Wood
Nardi & Button & Hub
Arm Rests
Shift Console
Dash top/cowl/face
Rocker Covers
Manual Pedal Set
Headliner / Visors
VDO gauge set
AC Console Sides
Stainless Door Sills
Gas Tank
Rear disks
Seats & Panels
Blinkers
Rear trunk interior trim
Front interior aluminum door jamb trim
Rear interior aluminum door jamb trim
Vinyl door jamb welts
Under Column dash panel
Parcel Tray wood/vinyl
Pending:
Front power window setup
All Rubber
Hot Ticket Still Available
AC setup
Bumpers (Better pics this week)
Early Skinny Booster
C-Pillar Roundels (raised aluminum)
Wiper / Blinker Stalks
4pc Lock set w/ key & column
Rear Disk Conversion
Front Vented Disk Conversion
bluecoupe30!
Wow, these parts appear to be moving quickly. I am sure this was a very difficult decision for Vitaliy to make, parting out a car you would want to make into your dream. So he held onto it for quite some time, and then made the choice. I am pleased Forum members have stepped up and helped move parts to worthwhile causes, and perhaps Vitaliy will feel good about helping others realize what he had hoped he could do with his Coupe, there is a lot of good stuff here! Appreciation to Markos for helping facilitate this endeavour. ;) Mike
Markos
Seattle, WA
Cross posting on facebook today. If you want something reach out sooner than later.
Available:
Braking:
  • Vented front disk/calipers
  • Rear Disk package (trailing arms, calipers, disks, parking brake cables, proportioning valve)
  • Brake booster (2800 CS skinny booster, good DCOE clearance)
  • Parking Brake Handle
Suspension & Drivetrain:
  • Ireland Engineering Adjustable Swaybars
  • Bilstein Struts Front/Rear
  • Rear Differential, 3.45 open
  • Rear Subframe
  • Front Subframe
  • Throttle linkages
  • Aluminum Radiator
  • 3pc Epsilon Mesh Wheels
Trim:
  • Euro-Early bumpers front/rear
  • License Plate lights (genuine Hella early)
  • Aluminum Roof Trim
  • Aluminum Windscreen Trim
  • Chrome Window Sill Trim
  • Aluminum Door Jamb Trim (near the striker)
  • Belt-Line Trim (piecemeal - nose, and one door sold)
  • Trunk Panels (tail panel sold)
  • Wheel arch elephant Skin Panels
  • Tail Lights
  • Tail center trim (early chrome)
  • Door handles (mechanisms below)
Exterior:
  • C-Pillar Roundels (1974+ raised aluminum)
  • Headlight Buckets, Glass, and Chrome
  • Front Grilles
  • Kidney Grill
  • Satin/Chrome wipers
  • Lock Set (see interior)
Metal Stuff:
  • Doors
  • Power Window Conversion (wiring, motors, regulators)
  • Trunk Lid
  • Hood Torsion Bar
  • Trunk Torsion Bar
  • Headlight Access Panel Covers
  • Curved Gas filler neck
  • Gas door
Interior & related:
  • AC setup (evap box, blend duct, hard lines, soft lines, Condenser, B35 compressor, AC Face Plate, AC Temp & Speed)
  • Steering Column and four piece lock set
  • Instruments (2800 CS off-white mph)
  • BMW Shift Knob (e12)
  • A/C Pillar Vinyl
  • Grab Handles,
  • Seatbelts
  • Glovebox
  • Fusebox Door (some damage)
  • Door mechanisms
TedS
SoCal
Is there a picture of the kidney grille? 4 or 5 slat?
Markos
Seattle, WA
Hi Markos-
Thanks, much appreciated. No worries if not, I may pick one up on BTS autoteile from a link Gransin shared.
Best,
Scott
I thought I replied. He has the 2800 badge. It is in fair shape with no locating/mounting pins. Would need to use typical 3M badge tape. Price should reflect condition.
e9coupeMA
I am interested in the A/C set up. and the brake parts. please contact me. Jamie 617.480.2629
Markos
Seattle, WA
I text a picture to Vitaliy. He should have one. He is a bit behind at the moment due to a busy week. FYI - I will advise him appropriately on value. These are hens teeth and never for sale. I’ve found two for other members and they were about $50 both times. Maybe someone reading this has a spare also. The 2002 radio and HL knobs look similar FWIW.
Markos
Seattle, WA
I am interested in the trailing arms and kit for a conversion to four discs. are they still available? here is my cell 617.480.2629.
I text Vitaliy about the brake parts. They are still available. If you are unfamiliar with the parts, I recorded a quick video on the subject. I can text you the link.
Drew Gregg
Ft. Lauderdale
Available:
Braking:
  • Rear Subframe
  • Front Subframe
  • Throttle linkages
  • Aluminum Radiator
Trim:
  • Tail Lights
Exterior:
  • Front Grilles
  • Kidney Grill
Metal Stuff:
  • Doors
  • Trunk Lid
  • Hood Torsion Bar
  • Trunk Torsion Bar
  • Gas door
Interior & related:
  • A/C Pillar Vinyl
  • Grab Handles,
  • Seatbelts
  • Glovebox
  • Door mechanisms
Are the curved inner wheel housing elephant skin covers available? Thanks, Drew
e9coupeMA
Hi Markos - Just seeing this now. Yes, please text me the link and thank you very much!
