Getrag 265 fits badly
Discussion in 'E9 General Discussion' started by wolfram, Apr 16, 2018.
  1. wolfram
    wolfram New Member
    18
    1
    3
    Hi! I have made a gearbox swap from Automatic to Getrag 265 CR
    Crossmember 23 71 1 175 731
    Rubber mount 23 71 1 175 732
    BUT. Problem with gearbox "bumping" into transmission- tunnel during acceleration.
    Wrong parts or do I have to prepare the tunnel by making it wider/higher? Best Regards/wolfram
  2. aearch
    aearch Well-Known Member Site Donor
    2,894
    187
    63
    pleasant hill , ca
    look at the fit and clearance at top
    if need be space down the bracket
    also is it the box or linkage?
    i have an adjustable linkage tower to push up to fit
    im sure you have the pad above to the tunnel hole
  3. sfdon
    sfdon Well-Known Member Site Donor
    4,094
    484
    83
    sfbay area
    Just install the new version from CK.
    Problem solved.
    The 5speed bracket was a kluge from day one.
  4. teahead
    teahead aka "Rob" Site Donor
    3,072
    506
    113
    Seattle, WA, USA
    GRKOALA and autowerks like this.
  5. CRJ Driver
    CRJ Driver Member
    68
    6
    8
    Camp Hill Pennsylvania
    Just received the KC mount as well...
    What a wonderfully streamlined product, if time equals money... I just paid myself handsomely.
  6. sfdon
    4,094
    484
    83
    sfbay area
    It’s built like a brick - fits perfect.
  7. rsporsche
    rsporsche Well-Known Member Site Donor $$
    6,762
    757
    113
    Atlanta, GA
    i will be buying and installing one when the new engine goes in.
    bdigel and teahead like this.
  8. aearch
    2,894
    187
    63
    pleasant hill , ca
    good fit
    but way too expensive for a simple mount
    there the pic make your own
  9. Stevehose
    Stevehose Well-Known Member Site Donor $
    View My Garage
    8,331
    907
    113
    New Orleans, LA
    I see the exhaust hangar is unattached, doe the CK muffler system not use this mount location? Only the manifolds, 2 at the rear can, and the exhaust tip one? I want this tranny support!
  10. rsporsche
    6,762
    757
    113
    Atlanta, GA
    i think this is just a pic for selling them - the linkage isn't hooked up on the tranny either.
    go ahead ... i think there is some fitting / engineering that took place on this ... and life is too short to worry about a few bucks. it works, its solid and its figured out.
    Gransin and teahead like this.
  11. sfdon
    4,094
    484
    83
    sfbay area
    Funny thing is the rubber support that is engineered for CK support is Febi for another bmw.
    Cost is 1/10 the price
  12. Arde
    Arde Well-Known Member
    2,981
    231
    63
    Cupertino, CA
    Glad to hear, I thought I would have to shift gears by sticking my finger into the transmission tunnel hole...
  13. sfdon
    4,094
    484
    83
    sfbay area
    Oh boy.....
  14. wolfram
    wolfram New Member
    18
    1
    3
  15. wolfram
    wolfram New Member
    18
    1
    3
    Thanx for tips.
    Feels a little heavy to go for a new set of parts after buying the above mentioned.
    It feels after all like a question of height. I'll have to find shorter rubberbushings, nicht wahr?
    wolfram
  16. inovermyhead
    inovermyhead Active Member
    475
    129
    43
    Sydney
    Wolfram, do you only get the problem when you accelerate reasonably hard in first gear, a thump thump noise?
    Cheers. John
  17. wolfram
    wolfram New Member
    18
    1
    3
    John.
    In fact it appears mostly in 2nd gear
  18. arnie
    arnie Active Member
    193
    35
    28
    Germany
    .... interesting solution from CK, but what is the separate brace for ?
    I can't see any purpose :rolleyes:
  19. inovermyhead
    475
    129
    43
    Sydney
  20. Wladek
    Wladek Active Member
    656
    219
    43
    Poland
    It's shifter mount base rear support.
    Shifter mount base in 5-speed Getrag is shorter, than 4-speed Getrag and is mounted only on two bolts to the gearbox (vs four bolts in 4-speed Getrag) so it have additional ear mount on the back side, so was rigid when gears changing.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
