Guys please chime in at any time for suggestion, ideas or question, ( if I can answer
I have done many 02 rebuilds in my life but this is my first E9,
I will explain a section then post pics, I had a couple of hours yesterday so,
1- Took the exhaust system off completely it was easier and I had a lift to use ( left the back Exhaust manifold on the head to grab when taking the head off)
2- Drain the antifreeze
3- Disconnect the battery
4- Rotate the engine to achieve TDC with the rotor pointing at number one cylinder and the notch on distributor lip, the timing marks on the crank shaft pulley and front engine cover should match as well ( Remove the lower radiator hose from the thermostat side to see the crank shaft pulley marks)
5- Loosen the distributor bolt and remove the distributor along with the distributor plug wires
6- Take the thermostat cover off, 4 size 10 MM bolts
7- Take the valve cover off, 8X10mm nuts and 1x 10mm bolt
