Help with VIN plates
Portugal
What numbers should be engraved on the "chassis number plate" as shown below? I bought a blank plate from Jaymic some time ago and now is time to fit it but… the thing is written in german and I'm not able to decipher it.
Is there another plate, like a “manufacturer plate” (Karmann Karroserie)? These are only things I haven’t labelled and I don’t know how they go.
x_atlas0
Clarkston, MI
The picture is not showing.
Based on what you are describing, it sounds like the tiny plate that goes in the front door jam on the driver's side. Has the VIN and paint code, along with production date.
Perhaps if you posted a link of this plate?
x_atlas0
Clarkston, MI
Here is a pic of the placement of the plate picture you sent me:
You can see it behind the right shock tower.
Portugal
Better.
Yes, that is exactly what I had figured. But what is it supposed to have written? "Typ" is the first line, the second is an enigmatic "Fahrgest.Nr." and the others must be weight parameters, in "kg".
Thanks.
x_atlas0
Clarkston, MI
Re: Better.
Thanks.
Typ: 3.0CS (or whatever model you have)
Fahrgest.Nr.= VIN, by the looks of a quick google search.
cdavie2002
Scotland
I have the V5 document, and the chassis number matches what is stamped into the bulkhead; however my chassis/vin plate is pretty much rusted away. Who can o get a replacement stamped chassis plate from?
Wladek
Gdansk, POLAND
Karmann door plate - have only colour number stamped in bottom line. Karmann didn't stamped chassis number in middle line.
BMW under hood plate with stamped VIN number + painted weight information (depends on engine type).
cdavie2002
Scotland
Yes, the 2nd of your attached pics, the plate showing VIN & weight info. That is what I need a replacement of.
