JelmerE12-E28
- Messages
- 27
- Reaction score
- 0
Today I've worked on the carbs again. One of the acceleration nozzles wasn't squirting enough so I swapped the pumps of the front and rear carburetor. This didn't change it so the pumps (with new skirts) are fine.
Next I took the carburetor section so that I could take the check ball out that gives acces to the acceleration pump. The ball wasn't sealing when I blew air from the pump side thru it so I took a check ball from another carburetor. This one was closing when blowing from the pump side so I put it in the carb section and bolted it back to the rest of the carb. Next I tried the acceleration pumps and now the have the same resistance and squirt equaly! Problem solved?!?
I took it for a spin and quess what! The hesitation is still present!!
I running out of ideas of what this could be. Could it be ignition related?
I have an electronic ignition but all vacuum lines are hooked up like factory. I also set my ignition at factory specs, with the ball centered at the flywheel inspection hole.
Any suggestion?
Any suggestion?
