Instrument gauge pods
Discussion in 'E9 General Discussion' started by Thomas76, Jan 12, 2019.
  1. Thomas76
    Thomas76 Member Site Donor
    45
    10
    8
    Michigan, USA
    This is new to me.... The black gauge bezels were bonded to the back plate with what appears to be a weld, has anyone delt with reassembly and have suggestions?
  2. Roger S
    Roger S Member
    149
    8
    18
    Queens, NY
    Scott just helped me with this same issue/concern. Use solder and tack it in a few spots.
    Regards.
  3. Koopman
    Koopman Well-Known Member Site Donor
    1,586
    140
    63
    Uxbridge,Ma
    If anyone has spares I would be interested.
  4. rsporsche
    rsporsche Well-Known Member Site Donor $$
    7,049
    895
    113
    Atlanta, GA
    Harry, spares of which? the trim rings, the back plate, the instruments or the wood?
  5. Koopman
    1,586
    140
    63
    Uxbridge,Ma
    Black plates and trim rings.
    Sorry
  6. BarryG
    BarryG solo e9 Site Donor
    802
    63
    28
    Nor*Cal - Rocklin, around the corner from Dan
    Harry
    I sent you a PM
    B
  7. Thomas76
    45
    10
    8
    Michigan, USA
    Interesting method, I'll give it a shot. May have to crank up the solder gun to 11.
  8. rsporsche
    7,049
    895
    113
    Atlanta, GA
    better to use a little butane torch than a soldering iron
    Thomas76 likes this.
  9. eriknetherlands
    eriknetherlands Active Member
    560
    197
    43
    Netherlands, Eindhoven area
    Why not use a sturdy 2k epoxy glue? Originality may demand solder, but epoxy will work I think.
    Verstuurd vanaf mijn SM-A520F met Tapatalk
  10. Thomas76
    45
    10
    8
    Michigan, USA
    I have not tried epoxy for metal on metal weld. Interesting...
  11. Ajay
    Ajay Member Site Donor
    43
    17
    8
    Irvine, CA
    Thomas you have to clean the old stuff off the rings and the backing plate of the gauge cluster really really good. I used a dremel then 500 the 800 sandpaper zoom it's super clean and smooth. Attached the rings with JB Weld overnight and it did fine. Make sure the rings are centered correctly as they are marked with a notch on the bottom.
  12. Koopman
    1,586
    140
    63
    Uxbridge,Ma
    Hi. I just used a generic Crazy Glue to replace a broken stud on the rear o a kidney and it worked. A very strong hold.
  13. rsporsche
    7,049
    895
    113
    Atlanta, GA
    i want to echo what Ajay said about cleaning the bottom of the rings and the metal back plate. first you want to make sure that you have removed enough of the old solder so the rings fit completely into the holes of the back plate - you really want there to be an overlap so you have something to catch the solder. you really need to heat the ring and back plate with some flux on the plate so the new solder will run into the gap and hold the two pieces together.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
