Hi Aviator,
$350 is a steal :shock:
Ok let me try and answer your questions and comments.
Yes it looks like an import to the US, the biggest give away from you pictures is the rear fog light which is a European thing... I don't think they are required in the US even today.
So lots of buttons to play with
Probably you have red, green and yellow push buttons scattered around the dash.
usually they are as follows:
red - hazard warning
yellow - rear fog light
green - heater rear window
However your new toy may of been mucked about with so things can change! Plus BMW seemed to change things around every five minutes so expect the unexpected!
THere may be two reset style breakers, these are for the electric windows as BMW had some issues with the windows, they are commonly rated to 8 amps
Some European models had the "fast" wiper speed controlled by a push/pull style switch on the central panel by the gearchange, others by the column stalk, you will just have to play :roll:
As to the odometer reading I suspect that your 1983 receipt is for 100345Kilometers about 63000 miles. thus I suspect if your reading is about 13492 thats another 8500 miles so you have a grand total of 78,000 miles, even if there is an extra 100K Kms in there thats still only around 150,000 miles not bad for a 30+ year old car!
From you photos there is rot in the rear , maybe has taken a knock at sometime on the RHS ( by the fuel filler) and of course the front wings (fenders). That would suggest your going to have to get the front wings off and have a look at the A-pillars.
Wood trim on the doors can be fixed, check out other restorations, especially
Steve in Reno who has restored and posted pictures of his restored wood.
Gazzol has done some fantastic work in regard to restoring and tweaking an E9
Floor Pan - well you can buy a pattern part which you can trim to fit and then weld in (or get somebody to do it for you)
Rear Bumper - Ask here for one or do the flea bay thing or put on a CSL reproduction fibreglass one (Oh dear I might get shot for saying that
Metal ones are available - check out Walloth and Nesch Germany as the ultimate BMW parts supplier.
Brakes - Probably rusted lines or knackered calipers, pistons or master cylinder, rebuild, exchange, or new. Maybe just lines. Change the flex hoses while your at it, cheap insurance.
VIN - Contact BMW Mobile Tradition they can tell you about the car and where it was first delivered . Lots of stuff on this site about contacting them, Fax, letter, email, or calling will work.
Windscreen - :roll: That's life. Local Windscreen (or shield) boys can help there.
Part out? restore? Thats up to you
think about the folloing:
Time, space, money, partner (if any) atitude!!!
Personally I have seen worse cases brought back from the dead, my old bucket (yeah, yeah still working on it) included!
Cheers
Malc
