sreams
I've been running Weber 32/36 DGVs on my M30B35 for quite a while now, and I believe I have them tuned about as well as they can be.
From what I've read and from my understanding of the CFM requirements of a 3.5L M30, I believe the DGVs are not adequate for the motor at WOT. I believe there is untapped power to be had. The Weber 38 DGES seems like the obvious choice, although I think I might still want to have a progressive setup for the better gas mileage it allows (I currently get a bit over 20mpg on the highway). I'm actually almost happy with the response provided by the primary 32mm barrel, so I'm thinking a 38mm primary would be perfect in a progressive setup.
So, I had the idea of getting the Weber 38s, and swapping the linkages from a spare set of DGVs I have to make them progressive. For those of you who have experience with both carbs, does it look like such a modification could be made? Does it sound like a good idea in order to end up with the best of both worlds (economy vs performance) on a 3.5L M30?
