My 73 mod 3,0SI Wont start when hot.
Jan-Arve Enoksen
New Member
Aalesund, Norway
Hi
Hope to get some suggestions from you guys. My 3,0 Si starts fine and runs fine. BUT if i stop it after running for 20 min or more ,it wont start until it has cooled down for a while. I havent checked fuel and ignition at that stage yet. Any suggestians will be appreciated. Where do i start to look?
teahead
aka "Rob"
Tacoma, WA, USA
starter solenoid getting too hot? Check for bad grounds on that starter. May need a new solenoid.
duct-tape
Atlanta, GA
Explain the symptoms, does it turn over?
I'm not familiar enough with djet to know if it has a hot/cold start feature.
If it turns over, pull a spark plugs and see if it's wet.
Jan-Arve Enoksen
New Member
Aalesund, Norway
Engine turns over.I have not checked spark plugs or fuel yet. But if i wait for 20-30 minutes ,it starts like normal again. As long as it runs , there are no problems. Only if i turn it of when it has normal cooling temp .
sfdon
sfbay area
When it won’t start-
Crank the car when hot and listen for injectors clicking at each injector using a screwdriver held to your ear.
Key on - operate throttle linkage at throttle body. Listen for injectors clicking.
Crank the car with a spark plug on your valve cover inserted into the coil wire end
Jan-Arve Enoksen
New Member
Aalesund, Norway
Will try these suggestions. What is the solution if it is these thing(s)?
duct-tape
Atlanta, GA
okay, it's not spark or your starter.
The Si system relies on fuel pressure but when the car gets hot, the rail gets hot and you get a version of vapor lock. 99% of the time, you can replace the fuel pressure regulator, and it wouldn't hurt to be a 5psi higher. otherwise, your fuel pump is getting tired and can't re-pressurize the line with the hot fuel vapors at the engine. Modern gas tends to vaporize at less than 35psi when it's over 120*f
sfdon
sfbay area
Just test for them.
No reason to write a book of solutions if neither is the problem.
Jan-Arve Enoksen
New Member
Aalesund, Norway
Thanks. I will look at that too. I already suspect fuel pump or pressure ,but would check here first for possible solutions.
I will report back when i have solved it.
