richrfd
I looked through the posts but did not see anything for sale. Does anyone have a working used one I can buy? I took mine apart and it's all rusty inside.
I have one.
E24 is exaclt the same. The wiring needs to be pulled around bit, as you say. The connectors on the motor faces in a different direction.Also, I was able to use one off an E12 and just move the wiring around a tiny bit (no cutting/splicing whatsoever). Early E24 probably the same too.
1. Only early e24;E24 is exaclt the same. The wiring needs to be pulled around bit, as you say. The connectors on the motor faces in a different direction.
