Oil pump: the hub mistery
FGS
Milano - Italy
Well, the original oil pump of my 3.0 CSi has definitely gone, so I bought a replacement oil pump part # 11411269550 which is said to be the correct one (and the only one on the catalog) and, indeed, the pump is basically the same of the old one
but
the new one has a splined shaft (where the hub should be) while the old one hasn't.
Has anyone ever had the same issue? Any clue?
sfdon
sfbay area
Sounds like you need to order the oil pump gear and nut
sfdon
sfbay area
Sr. dQ- can you help us out with pics of the 3 gears and when they get used?
This makes me frustrated!
Thanks!
FGS
Milano - Italy
Here they are: old (left, with the hub) vs. New
The hub can't be moved on the new one as the old one hasn't a spline.
sfdon
sfbay area
There are 3 gears used in these engines (the big six)
1 is bolted on with 3 bolts. That's the early version
2 are splined and use a nut. These later 2 are divided again into big and small.
Big and small are actually also early and later.
3 gears:
Early...bolt on
http://www.realoem.com/bmw/enUS/showparts?id=3435-USA-08-1971-E9-BMW-30CS&diagId=11_2583
Later same size...splined
http://www.realoem.com/bmw/enUS/showparts?id=3435-USA-08-1971-E9-BMW-30CS&diagId=11_2585
Later splined
http://www.realoem.com/bmw/enUS/showparts?id=GB43-USA-05-1992-E32-BMW-735i&diagId=11_4602
Here's the fun page-
http://www.realoem.com/bmw/enUS/sho..._1984_E28_BMW_535i&diagId=11_2135#11417577655
Any mistakes I'm blaming on dQ!!
deQuincey
Quousque tandem...?
appreciations and blessings to you :wink:
an additional point to comment is that depending on your engine oil bottom cover, newer versions of the oil pump will interfere with the cover
the swamp in old pumps is a flat grille, but new versions have an additional cylindrical cover with an uncentered 1" hole, be aware of that because you might be unable to put the bottom cover, there is a 10mm interference thus you should cut the additional cylindrical cover of the oil pump swamp
(i know, it is diffciult to explain but i dont have a picture,
blame on dQ again...)
sfdon
sfbay area
Old and new and big and little 3 gears pic
