OTHER STUFF
aearch
pleasant hill , ca
so thye rear axle bearing was screaming "change me"
so pulled it apart and the emer brake pads were also in pieces
so good fix new bearing and pads
fun
cleaned and painted all the brake dodads.
my wife wont let me do anything without three supports
go figure
autokunst
Milwaukee, WI
I just want to know how many fasteners you've had to fish out of the trench drain, let alone find in the brick paver joints or under leaves.
Stan
Newmarket, New Hampshire
fun
go figure
Smart woman - one squashing is enough
Wes
Tasmania, Australia
You get away with only three supports, lucky man.
Had 5 when I pulled the gear box and motor but was working alone.
7 if you count 2 x bits of 4 by 2s suck in the car stands so she couldn't roll back.
The hand brake was also on...
aearch
pleasant hill , ca
3DAY JOB
so there is no way to get the bearing out while on the car.
so pulled the lower trailing arm in 2 minutes and
then set it on blocks and sledge hammered it out
it went bake in super easy.
cleaned and painted all the parts and can finish up in the morn
used up a couple hours trying to get it out while bolted up
no go.
no more whining
