BradCSI
Hello
I wanted to share this information with the group, I thought it could be useful.
The men from Mars are a group that are in most major cities in the US, they go to dealerships and cosmeticly repair cars.
They repaired a 1 inch cut in my Aston Martin's Connely leather seat. It was perfect and cost effective.
Here is MARS phone # 972-647-6277 a
Web site:
http://www.marsinternational.com
Discription:
Miracle Magic Hard Plastic Repair
M.A.R.S. Operators are able to repair and reconstruct those expensive interior trim pieces. As plastic ages, it can become brittle and crack, or even break anytime stress or pressure is applied. With the MA.R.S. plastic repair service, your interior plastic will be restored to their original appearance. With the M.A.R.S. Hard Plastic Repair service, restore virtually any interior plastic piece to its original look and finish at a fraction of the replacement cost.
M.A.R.S. Miracle Magic Vinyl Repair System
The M.A.R.S. Miracle Vinyl Repair System will allow you to quickly and easily fix tears, holes and cuts to vinyl. You can quickly and easily fix the damaged area leaving it flexible, and virtually undetectable. While the usage of vinyl has declined in automobiles over the years it is still very popular on furniture, restaurant seats, and buses. You can literally fix hundreds of items with this system. This system uses heat to cure the compounds eliminating waiting for chemicals and compounds to dry. Most repairs can be completed in 20 - 30 minutes and when finished the area repair will actually be stronger than the vinyl around the repair area. After the repair is completed a little work with the Comprehensive Dyeing System you will be able to leave behind a strong, flexible, and most importantly undetectable repair.
M.A.R.S. Miracle Leather Repair System
As leather interiors become more and more popular in vehicles today leather repair is also becoming a more popular system. Many of our competitors will tell you can fix leather the same as vinyl. We believe that is a mistake. Leather is a completely different material and needs its own repair process. Leather is very sensitive to heat and since heat is needed to make vinyl repair compounds cure it is easy to damage leather using the vinyl repair methods. The M.A.R.S. Leather Repair System will allow you repair leather without the use of heat as our leather repair compounds all air cure. We have spent years researching what we believe to be the best leather repair system available today. With this system you will be able to fix everything from wear lines in the leather to large holes and rips. When the repair process is complete you will be left with a strong undetectable repair that still retains the soft supple feel of leather.
Miracle Magic Velour Repair System
There are very few things that can make a good interior look worse than a burn in the seats or carpets. The Miracle Magic Velour system will allow you to quickly and easily remove these troublesome problems. This is another system that has become more and more accepted as a cost effective repair. Most repairs can be finished in minutes. Traditionally, these repairs only were expected to last 6 months to a year, but through technological advances and superior repair methods, your repairs can be expected to last for many years. Even those multi-color fabrics and patterns won't be a problem with the M.A.R.S. Miracle Magic Velour Repair System.
Thanks,
Brad
Web site:
Discription:
Thanks,
Brad
