Farzad Arjmand
My 3.0CSI was running smooth and flawless , until I installed my new radio in dash and used fuse #8 as on/off power source . after installation is finished , I started the car and it was running very ruff and black smoke coming out of tail pipe. I checked the fuse box noticed fuse # 6 auto choke has no wires attached to it. thinking that I may have disconnected the #6 wire , I looked every where , but nothing is there. So I went under neath the back seat to check the wiring of the box ( I don't know the name of it) nothing seemed out of place , there is a little knob in the back of the box , thinking that it may be fuse ,I turned it over and over in each direction .... AM I OVER MY HEAD on this one?? I checked the small relay box next to it in the back seat and no voltage is showing in my voltage meter .... any suggestions?? did I screw up the setting by turning the knob?? Car was running bad before I touched it ..... My Sunday has a bad start.
