Lan-renewal of door trim, rubbers, clean and regrease of mechanisms,...
deQuincey
Quousque tandem...?
Thanks DeQuincey - well done and invaluable documentation.
2 questions...
(1) I believe I have the clips inserted correctly. They just slide over the metal at provided gaps in the felt backing strip? Then I suppose they create a friction fit against door top?
(2) The NLA rubber that's shown in my photo just below the chrome trim affixes to front edge of trim - guessing with some spray adhesive. But, what about the second one down? It's heavier/ stiffer rubber and I have replacement new rubber for it. Anyone know where that piece goes?
Thanks!
(1) yes
that rubber(2) goes inside the car, i mean closes the gap around the triangular window between the chromed frame and the inner upper trim, take a close look to it in my thread
sent you a pm
RTHLSS1
Slovenia
How do you remove this section with wood?
JamesE30
Germany
Just read through this post and wanted to say thanks for all the detailed pictures and info! A great resource for when I’m putting my car back together!
Last night i was actually working on cleaning some of these parts as well. Some of the old grease on these mechanisms was rock hard! I had to soak them and brake cleaner and eventually could chip the grease off with a wooden scraper.
I actually planned to replate these parts along with all the other door stuff. But the plater didn’t look too impressed with the state of them haha and asked if I could clean them a bit and take them apart..
I see there is no way to remove the spring without fabricating a fixing point similar to yours. Anyone know if it’s ok to leave the spring on during replating?
Wladek
Gdansk, POLAND
Spring can be disassembled easily without any damaging. Spring is slided in.
Now your mechanism is in closed position & spring have full tension on it, so you need to make mechanism in open position (tension will be much reduced) & you will be able to continue the work.
Then, pull the spring from the fastener (bent end) & then you just need to pry it from the bottom with big flat screwdriver.
Spring, during the plating process, when there is tension on it can break.
That type of springs better tolerate oxydation/blackaning process, than zinc plating.
deQuincey
Quousque tandem...?
@JamesE30
again you should call the person like this @deQuincey so he will notice your question
i do not think your mechanisms are in need of plating, those mechs can not be dissasembled, plating can be done though, but i would not recommend
you can remove the spring easily, just drive the mech to the end in which the spring is almost relased
JamesE30
Germany
Ooohh of course! Ok thanks for the tip!
@JamesE30
I must admit I thought the same after cleaning them.. they actually look pretty good. But since I am having a whole bunch of stuff done anyway I thought I would also get these plated. Why would you not reccomend it?
Wladek
Gdansk, POLAND
With zinc plating there is one major problem - person who is making it. Of course part should be also good prepared/cleaned/degreased/sometimes blasted etc.
If something will be done wrong in process you might have imperfections & then rust instead of zinc.
RTHLSS1
Slovenia
@deQuincey noted. I have removed that section.
How do I remove vent window. I have removed all that is marked on photo but when I try to pull out window the 2 "spindles" marked red are preventing to put window out they. What is the trick?
deQuincey
Quousque tandem...?
those spindles belong to the vent window mechanism, that mechanism must be removed from below, you must find a bolt that links the vent window with that mechanism. remove it, and let the vent window free from the mechanism, only this way you will be able to take out the whole vent window assembly
nico13
Lochem, The Netherlands
Hi deQuincey,
I am planning to restore my doors too, your post is a great help, but it seams that many photo's are missing or deleted.
Are the photo's still available?
Further the window liner in the triangel window, how is that kept in the slot. In my case it is moving with sliding the window up and down.
Regards,
Nico
deQuincey
Quousque tandem...?
Mark Jarman
Seattle, WA
assembly almost done, some facts and tips
the assembly of all the elements is not difficult, but there are two important aspects,
first of all is the need of a sequence, some elements can be assembled, others can be compromised and impossible to introduce once other parts are mounted
second, is the inherent difficulty of the adjustment of all the elements to provide a correct movement and fit of the window
my experience says, that for a completely dissasembled door, the sequence is :
first is the outer handle and its mechanism, then is the door lock mechanism, then the door lock itself, following this sequence it is straight forward, but one last issue, the final adjustment of the outer handle must be done at the end of this block of parts
(do not assembly now the inner handle mechanism, this IMHO is the last mech to be assembled in the whole door)
when this is finished, the next part is the triangular vent window, the complete frame, place it in its position , but do not tighten the nuts and bolts
then the window glass itself, but to introduce it you will have to remove the big support that move along the rear guide,
then introduce the rear guide, and with this part in position, introduce and fix the above mentioned support,
now introduce the vent window mechanism from under
before any window adjustment, introduce the window lift mechanism, the adjustment will be influenced by the whole system
in my experience, the adjustment is too complicate, not only you will have to compensate the paralelism of the guides, but the position of the mentioned big support within the window glass is also an aspect to be considered
it is also critical the position of the lower supports of the guides, these two points, one in the front and the other in the rear are the responsibles for the top of the window to move inwards or outwards
this adjustment is critical for a good closing of the front and rear windows one against the other, but is critical for the closure of the triangular and front window against the door top frame too
i am still preparing an alternative rubber part for the NLA one in the weatherstrip, so my experience finishes here, but i assume that now i will have to assembly the outer weatherstrip, then the inner one that carries the wood trim part too
then the door foil (this will not be done for some weeks while testing that all works correctly)
then the door panel, and then the arm support, the door handle, the window lifter handle, the ashtray
....und das ist alles !
deQuincey -
Your assembly order is very helpful. Do you recall and tips to installing the exterior chrome piece with the window sweep/weather-stripping?
I'm thinking you put the clips on the door first and then push the chrome piece down over the clips.
Thank you.
Mark
deQuincey
Quousque tandem...?
deQuincey -
Thank you.
Mark
mark,
i do not remember, but in principle the clips usually go first in the piece that you want to assembly and then you put everything to the door
please post your pics and we will try to remember from there
eriknetherlands
Netherlands, Eindhoven area
mark,
Mark, i indeed followed the order that DQ posted above. (clips inside trim, then the trim on the door). I also put a generous dab of grease on the clips where the sharp teeth bite into the paint. I hope that this way any future rust is kept 'sleeping'.
Midwestbike
Nashville, IN
sorry thread is 9 years old,
all covered in dust
apologies
I know the thread is old and was hopeful it would still be around. What I don’t understand is why we can’t buy that spring holder/pin as a separate unit. It has to be in production somewhere because 2002 window regulators are still available and Mercedes Benz has regulators and the holder/pin is similar if not the same. Well time to keep looking…
Thank you for the quick reply
