side grill removal
Discussion in 'E9 General Discussion' started by Drew20, Feb 12, 2019.
  1. Drew20
    Drew20 Active Member
    248
    51
    28
    Beaconsfield
    Hi, newbie question I'm afraid... how do the side grills (on front wing/fender) come off?
    I want to replace the black vinyl underneath the grill but not clear if it just pulls off, or if there's a fixing I need to get to.
    I found this thread, which talks about small fixings, but where are they? Do I need to remove the protective piece of steel at rear of the wheel arch for access?
    https://e9coupe.com/forum/threads/side-grilles.5016/#post-29891
    Drew
  2. HB Chris
    HB Chris Well-Known Member Site Donor $$
    View My Showcase
    10,812
    1,300
    113
    Huntington Beach, CA
    Just reach behind the grilles and you can see what attachment method was used. The spring clip refuses to disengage from the plastic posts if that was used. No covers need to be removed.
    Drew20 likes this.
  3. Drew20
    248
    51
    28
    Beaconsfield
    Hi Chris,
    Could you pls expand on reaching behind the grill? The fixings are not accessible so far as I can see, as I can't reach them from inside the wheel arch, or from inside the car cabin.
    At the rear of the wheel arches there is a piece of steel to stop mud etc getting lodged in between the inner and outer wings/fenders. I think these may need to come off to get the access I need. However they're coated in sealant, so it might take a bit of archaeology to do this. I'm not 100% sure this will get me into the box space I need to access however
  4. Philippe db
    Philippe db Active Member
    725
    196
    43
    Belgium
    That indeed is your problem, this is not a standard piece and is what prevents you from reaching the grilles.
    I cross my fingers that you don't find any horrors hiding behind these guards.
    Drew20 likes this.
  5. Drew20
    248
    51
    28
    Beaconsfield
    Hi Philippe,
    these are the steel pieces I am talking about, discussed in this thread:
    https://e9coupe.com/forum/threads/inner-fender-covering-plate-s-questions.15938/
    hadn't realised they are a two part element, but per realoem there is an upper and lower "covering plate" on each side
    These are standard factory parts, so far as I am aware, looks like they need to come off then. And yes, fingers crossed for no lurking rust and plenty of waxoyl
    cheers
    Drew
    edit:
    think I've just answered my question, as in one of Steve's piccies I think I can actually see the fixings I'm looking for. Game on!
  6. Keshav
    Keshav Well-Known Member Site Donor
    1,319
    718
    113
    Weiterstadt, Germany
    Inside view
    autokunst and Drew20 like this.
  7. Drew20
    248
    51
    28
    Beaconsfield
    lovely, you could eat your dinner off that
    pretty sure my wing is not going to be so....immaculate!
    Keshav likes this.
  8. Philippe db
    725
    196
    43
    Belgium
    Hi Drew,
    These indeed are original but they won't prevent acces to the grills as you figured out yourself.
    Drew20 likes this.
  9. Stevehose
    Stevehose Well-Known Member Site Donor $
    View My Showcase
    8,790
    1,183
    113
    New Orleans, LA
    Take some pics of your inner fenders opposite the grills
    Drew20 likes this.
  10. m5bb
    m5bb Well-Known Member Site Donor $
    View My Showcase
    1,451
    204
    63
    Peachtree Corners, GA
    As discussed on another page, when you try to remove what looks like a rubber washer/disk it is in fact a rubber washer covering a piece of spring steel that has a hole in it to fit over the posts to hold the grill on. What doesn't show is that hole in the spring steel has little teeth that are one way only. You push it on and it grabs the plastic shaft of the grill and it is extremely difficult to remove with out breaking the mounting shaft of the grill.
    Just warning you so you won't do what so many others have done including myself.
    Good luck.
    JayWltrs and Drew20 like this.
  11. Stan
    Stan Well-Known Member Site Donor
    View My Showcase
    5,507
    474
    83
    Newmarket, New Hampshire
    can you use a needle nose pliers to bend out the tabs of the spring steel?
    Drew20 likes this.
  12. m5bb
    View My Showcase
    1,451
    204
    63
    It would be very difficult to get the pliers in the fender and get a hold of the rubber washer and the steel disk is inside the rubber washer. I did notice that if you squeeze them inward toward the body the spring steel disk will release the teeth and you can pull it off. We'll great when it pressed up tight to the fender and there is no room to bend it. I'll get a photo today and post it. It's hard to explain.
    It's like BMW designed this for one way only and when you pry them off the posts break and you have to buy another.
    Drew20 likes this.
  13. eriknetherlands
    eriknetherlands Active Member
    611
    225
    43
    Netherlands, Eindhoven area
    The steel springs are, for me, one time use only. if you need to remove them, cut them in half with strong pliers and buy a new one...The steel spring that is, not the grille.
    Drew20 likes this.
  14. m5bb
    View My Showcase
    1,451
    204
    63
    Here's a couple photos showing the spring steel inside the rubber washer. Note the nasty teeth it has.
    Makes it a little easier to understand.
    Drew20 and Gransin like this.
  15. Drew20
    248
    51
    28
    Beaconsfield
    +1
    I got around to this job last night and I cut the steel spring washers off with side cutters, reasonably good access to do this. Looking at better options for re-attachment, there's another thread on this exact topic in the restos section.
    But now I can get the black vinyl templated
    Perhaps using a die to put some threads on the plastic legs, and some nylon nuts.....?
    All looks clean and solid under the cover, although the cover itself is missing the rubber edging and was stuck very firmly in place with seam sealer :mad:
    Took a Stanley knife and lots of judicious yanking to get it out without bending it. Based on realoem I was expecting the cover to be two piece, mine was one piece, held in by a lug and 5 screws. Guessing this is not factory
  16. Stan
    View My Showcase
    5,507
    474
    83
    Those vinyl backgrounds are available I think for either LaJolla or Coupe King
    Maybe even Max or W7N
    adawil2002 likes this.
  17. rsporsche
    rsporsche Well-Known Member Site Donor $$
    7,329
    990
    113
    Atlanta, GA
    they are available from Coupeking - i have a set from them that will go on my coupe soon. they are $33/ set from CK ... http://www.coupeking.com/shop/product/fender-vent-blinds-e9-cs/
    they are cheaper from W+N, A51131827285 - 12.18 euro (w/o VAT) .... you just have to be ordering other things to spread that 49 euro shipping around.
  18. Keshav
    1,319
    718
    113
    Per W/N, the grills should be available in 2 odd weeks.... early March hopefully.
  19. Drew20
    248
    51
    28
    Beaconsfield
    Hi, a reprise of this old thread. I've cut out vinyl decals to sit behind the side vent grills, but am wondering if they're a bit too big, as they stick out above and below the grills. Photos probably describe this better!
    Is this right? I've plenty of vinyl, to redo these if need be
    Ta
  20. Honolulu
    Honolulu Well-Known Member
    1,465
    46
    48
    Honolulu Hawaii
    Who is going to know if the vinyl you cut is too big or too small? Maybe 2 people on this list... that makes 1 in several million worldwide. If you like it, let it be!
    one man's opinion, anyway, and worth the price, too.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
