The Life Story of my '71 Bavaria 2800
rickysbmw320i
I have kept most of the info on other sites but It's time for you to meet her.
Posted from another site:
Long time listener, first time caller....
First off, some damn nice cars in here, keep up the good work guys!
And now to introduce my project.
History.... (you do not have to read, but it is entertaining)
Basically I picked up a Bavaria up in Oregon a couple months ago.I traded a 1994 Cherokee for the car.
All I knew was that the car was in Portland, OR and I was in SF.
The car had been sitting for years and it ran fine when it was parked. Me and 3 buddies drove up and planned to drive it home.
When we got there, we found a broken fan clutch and leaky fuel lines so the engine could not pump fuel. We fixed that after 3 hours in 112 degree weather. We are on the road!
The trip: Took 3 days.
Gas was first.
The very first thing that went wrong less then a mile away from your house was the throttle cable. There is a spline that was stripped so we fixed that at some gas station. It was so hot (i think 110) and a guy gave us some free waters and then another mechanic came by and asked if we needed anything. We did need a spring to hold the carbs shut. So we got that and the stripped spine fixed within 2 hours.
Code showing his appreciation of H2O
We started to head down the road to "horsepower freaks" to go and visit. We got there and hung out for a bit....
but when we were walking back to the car, we noticed it was dripping from the transmission pretty bad. So we pulled into a shop real quick and tightened the tranny bolt. People were so nice there.
As we started to head home, we pulled out of the driveway and the car shut down. So after a couple hours of trying to figure out what it was, we realized the fuel pump was clogged, so we had a spare in the trunk plugged that in and primed the system.Note everytime we had to fix something, we had to pull out about 100lbs of **** out of the trunk.
It started up and again and we were off. Solid Driving that night! No problems, we were so happy.Minus the heat...
Ryan
Me
11:00pm that night I was sitting in the back seat and noticed the center divide was very bright. What could that be? Police? ****! Nope! We were on fire.... We pull over, through everything out of the car as quick as we could and threw it onto the shoulder. Pablo Saved the bavaria and put out the fire. We were 20 miles south of Eugene, OR on I-5. We didn't know that and we tried to call for police but only my phone had battery out of the 4 we had. So after 1.5 hours, a tow truck found us and hauled us to Eugine and dropped us off in a neighborhood. We walked to a motel, and finally got some sleep since we were up from 8 the previous night when we left SF.
The next morning we looked at the damage. Note we have no money or phones. We found a little german shop we pushed the car to.
Yes, Pablo had a chance to ghost ride ride it
We checked out the damage real quick. They needed the lift and helped us so much by just letting us check it for a couple of minutes We must have drank their whole 5 gallons of cold crisp water. We were so dehydrated.
To our surprise...
The drivers side rear brake must have been rubbing and caused so much heat it caught fire. It split the brake disc in half. So we pushed it again down the street and jacked up the car using the oem bmw tools, and removed the brake rotor. bolted the wheel back on. Thankfully the fire cause the whole caliper to seized so we didn't have to bleed the system. We also managed to get distracted by lighting a squished squirrel on fire.
We headed off and no problems occurred until we got to the State park by the CA border. We noticed the passenger side rear wheel was very hot. So we jacked it up, and pulled the brake disc on that side too. SO we had no rear brakes.
And back onto the road...Until....Problems!
We started to get to Eureka,CA. Around 11:00pm. Then realized we had NO BRAKES! We downshifted to a roll at an exit and found ourselves in an abandoned denny's. We had no idea what was going on. After 2 hours we found out that the rear caliper finally un siezed and was leaking causing no pressure in the system. So we found a fence and snapped the tip off to fit it in between the calipers where the rotor would be.
That seemed to work. The next 6 hours we headed home with 1.5 brakes. The right front work way to good and the left front barely worked.
We did get home finally and I left it alone for about 2 weeks.
I Then drove it to my friends shop where I was going to overhaul everything mechanically.
Things I've done:
The old tranny was leaking to much for my liking so I decided I will somehow put a newer BMW 5-speed tranny in it.
-Put 5-speed Getrag 265/6
-New Shift linkage plate (e28)
-New clutch
-Machined Pressure plate
-New rear main seal
-New pilot bearing
-Had to fab up a cross member for the tranny
-Shortened and balanced the driveshaft
Brakes:
-New rotors
-New Calipers (2002 tii front calipers)
-New Pads
-New lines
Other things:
-17'' BBS style 5 wheels
-Tires
-New radiator
-Alternator from e28
-Sound system
-Fixed most the lights
-Another fuel of filter
-Wheel bearings
-Exhaust hangers
-Removed old cruise control unit
-Adjusted Carbs
-New fenders
-New bumper
-New bumper brackets
-valve cover gasket
-Fixed power steering leak
-Cap, Rotor, Plugs, etc
So, I have been driving it every day (at least 60 miles a day) for the last several weeks and I couldn't be happier. I love the thing and have so more work to do.
Next is paint, some interior stuff, and coilovers.
I'll keep this thread updated as I go.
rickysbmw320i
Well, The pics kinda suck. I was in a rush and did not have a tripod. But you get the idea.
Rick
rickysbmw320i
Well, I have been kinda making progress.
Unfortunately, somebody blew the rings in the engine 2 weekends ago. But, I already picked up a m30b35 out of an e34. So, that should be going in soon. I also managed to get my wood steering wheel refinished and am working on rear headrests. I also picked up small pieces that have been missing.
rickysbmw320i
Welding in a new front clip before I do the engine. This one is bent and destroyed.
some cell pics...
Cutting the front clip off getting ready for the new one....
and one more.......
Cell phone pics....
rickysbmw320i
Below shows the new front clip! exciting! should be all welded up in the next few days.
Getting ready for paint!
CSteve
Bucks County, PA
You guys are great. More Balls and knowhow than the Pittsburgh Steelers. Enjoyed every word every photo.
Keep us posted.
Steve
rickysbmw320i
oh, and just got this from the owner of the body shop.
Huge update!
Removing the battery trey.
outside the booth peeking through
in the booth now
looks so sad...
new clip on....
getting towed back home for the engine swap
Isn't that just b-e-a-utiful!?
this is where they cut. Can't even tell!
I want to thank Gabriel at UACC in Burlingame,CA
Him and his team specializes in alot of older vehicles and does an amazing job. If you look in your upcoming performance BMW magazine, you will see some of his work shown. Highly recommend Gab for any type of body work. As some of you know, this is the same place that jabber jaw was restored!
rickysbmw320i
The Refinished MOMO steering wheel
The Manifold I had cut and rewelded. Except they really messed up. You can see the lines I made for them to cut and they failed. Have to get that redone.
And the Bavaria keeps warm sitting next to my buddy's Turbo 02
cheers!
rickysbmw320i
Alrighty folks, I have had alot on my plate lately so it's been hard to post up pics and update.
So, In order for this engine to fit properly, I had to use the oil pan from the old engine so it clears the subframe. That also means you need to change the the oil sump pickup. And of course there are small differences. So I ended up taking the old oil sump neck, bolted it to the new engine's oil pump and bolted on the old pan. Also replaced the rear main seal.
As for the clutch, I used the one I recently bought from the 5-speed swap. The new engine has a 30lb dual mass flywheel. Threw that out and used my 14 pounder. Can't wait to feel that!
After It was prepped, We started to put this beast in. Note it was 10pm on a Monday night.
So after 12:00 no luck....
We were so tired and it just didn't want to go in. I slept on it and started working on it by myself the next afternoon. later that day my roommate rolled through and lent me a hand. We had a bad angle on the tranny the whole time and thats why it wouldn't budge. So, We jacked it up a bit and the tranny clicked to the engine. Sounded like Lego's snapping together. Finally the engine was in and I could finally return that hoist that was costing me $40 a damn day.
And of coarse the booster would not fit with the manifold so I had to figure that out to. Either I could cut the booster more or find an epicly rare and expensive booster from a 2002tii. I ended up finding one at the shop and started to figure out what I had to do in order for that to fit. I had to shorted the shaft going to the brake pedal and use some random hardware but its finally all in. And look at that, it fits!
Old booster
New Booster
Did some wiring and bolted on the headers. I also managed to get my hands on a barely used radiator from a 79 5 series. Fits perfect! And looks sex with the electric fan in front of it.
lots of room!
Also Ripped out the A/C system and started mocking up a new custom center console.
Last but not least, started working on the Fuel injection pumps. grabbed a low pressure sender from a 82 320i and a high pressure pump from a '86 5 series (like mike's 5er).
that's all for now. I eventually will take everything apart again and paint and clean BUT.... I have to try to get this running before the 22nd of this month. I am trying to drive it to L.A. for a huge BMW show. We will see
Thats all I have But will keep you guys updated as well!
-Rick
CSteve
Bucks County, PA
You are making amazing progress. I just remembered, my mechanic who worked for an independent shop for years and years has a Bavaria tool kit shell(no tools) still in the original parts bag. Never installed.
If you are interested let me know. I can send pics. This is cherry.
Prefer you contact my at [email protected]
Steve
pamp
Comox, B.C. CANADA
Balls up
Man,
You guys have some Balls! Wood in the caliper? Just cannot figure how you got away with this one...I have a 3.5 manifold that is a bit dinged but probably better than what you have.
Yours for the cost of shipping. PM me if you want it and / or photos
coupe2800cs
Oakland California
3.5 Conversion injection or no injection?
You should toss that injection, use the new MSD 6 programmable ignition that came out last month, and slap some 45mm Webers on that beast... Alvin Tan's shop does really nice body work, you just don't see that type of work these days anymore... Complete paint job's start at $10,000 last I was in there, did they use Acrylic Enamel or Euro-thane to match the cars paint? Agave Green...
careysd
Phoenix, AZ
Ricky, nice job. Getting ready to do this this weekend. Ready for the fun. I was going to go with the L-Jet manifold, but have chosen not to. A couple questions for you:
1. What booster was that you went with? I have heard that gently massaging the stock one with a hammer will work. Thoughts or opinions?
2. What about cutting down/shortening the booster bracket that pushes it so far out into the engine bay. Take about 3" out of it and reweld?
3. Throttle linkage? What did you come up with?
Thanks, watching and learning...
Scott
