I bought a set of lights from Enoz. When I tried to mount them I found they could not be made tight enough to keep the lamp in place. Look at the first pic: A is a cup shaped thick metal washer and B is where the pivot point is. Right in between you can barely see a square protrusion that prevents the cup washer from snugging up to the pivot point. Pic 2 shows that squared off area better. I think this is missing a piece. The fog lights are useless if I cannot mount them.
Ideas? Should Enoz take them back?
