I have a terrific 1973 Bavaria survivor that I purchased from the original owner a few years ago. It sat for a few years before I picked it up so the usual stuff needed to be addressed. I had a local shop adjust the dual Zeniths with the plan to rebuild them once I put some miles on the Bav. Not more than a few drives into enjoying the car a major oil leak spung from the front of the car. Further the car smokes a lot when engine braking (rings are bad). I took the car in for an estimate for the oil leak and also asked about replacing the rings. The local BMW shop's owner is older and is well versed in my Bav and actually worked on it in the 80's. He is the only one who can work on the car at his shop, but he is semi/mostly retired. After many months I finally hear that it is not possible to get the parts to rebuild the engine and he suggests that I just fix the oil leak and rebuild the carbs.
Here are some of the estimates:
Rebuild one zenith carb- $760
Engine oil dye and clean- $182
Engine diagnosis- $135
Fuel filter- $148
Front crankshaft seal- $841
Valve adj- $416
Power steering flush and hose replacement- $745
So is it true that one cannot obtain the parts to rebuild an M30? is this the going rate for repairs? I was pretty floored by the prices but perhaps this is the going rate...
My goal is to get it running well and drive it as a survivor, but not sure if the cost to rebuild is worth what the vehicle is worth. Perhaps an engine swap... Its a shame though as the care has Zero rust, never in an accident and is a complete unmodified survivor.
I have had a generous offer from a member in Sacramento (I'm in Chico) to use his garage and knowledge that I will likely take him up on to tackle a fix of two, but will need to get the massive oil leak resolved first.
Thanks for any input, Steve
Fuel filter- $148
Valve adj- $416
