americium
I’ve been slowly but surely working on this 2800 to get it road ready and reliable. I changed the oil and filter, installed new plugs, wires, cap and rotor. Had new points in it but changed to Pertronix. I took it out for a drive when it had points and it was running ok but after a while it was acting like it was running on fewer cylinders and would come back to full power randomly. That’s when I changed to the Pertronix and also put in a new fuel pump and gas filter. I test drove it again and for a while it seemed ok then it started dropping power again.
I pulled the air cleaner off and followed the carb tuning procedure (still has the Solex carbs) of adjusting the idle speed and idle mixture screws to sync the them. I noticed that the idle speed on the front carb has no effect but the rear does. The mixture screw had some effect but it was most significant on the rear, the front only had a minor effect. I have an air flow gauge and I could see changes in the air flow when adjusting the rear carb but nothing changes the front. I could get the ball to float about 3/4 of the way up the scale on the rear carb but could not get the ball to drop at all on the front.
I did observe that both chokes are fully open when I did the adjusting.
I would appreciate any insights or advice as to next steps. I’d like to change to the dual Weber’s that would bolt on the existing manifold but I won’t be able to do it for a while so in the meantime I’d like to get it running with the Solex carbs if possible.
