Turn indicator stalk w/ wipe function for e9 SOLD
Sebs
Germany
Hi,
I have this turn indicator switch for sale. Located right hand side of the steering wheel.
BMW part # is 61311351852 . Good solid condition. Not worn out.
90 EUR + 9 EUR shipping worldwide. Would be nice to add 4 EUR paypal fees but isnt a must.
I'm located in Germany
Please send me a PM if interested.
Sebs
Drew Gregg
Ft. Lauderdale
you have pm
tganks
Jesus--My turn signal stalk will not activate the turn signal relay every time I turn the stalk up or down. I have to jiggle the stalk to power the relay. The wiper and wash functions are fine.
It seems that there are 2 part #'s for the same switch--61311351852 is on the W&N site and 61311355322 is on another site.
Do you know the difference?
My Coupe is 2250486 made in Feb 1973.
Thanks, Drew
deQuincey
Quousque tandem...?
Thanks, Drew
hi Drew, thank you for your question, I will try to respond later today when at home
regards
Drew Gregg
Ft. Lauderdale
regards
Jesus--I'm pretty sure I have this figured out. The stalk part# 852 is the Euro switch with individual spades on each wire. The Stalk # 322 is the USA version with a terminal block at the end of the wiring. The USA switch has white lettering--wipe and wash-- on the end of the stalk. Your Euro stalk just has the symbols on the end of the stalk.
I was able to buy a NOS USA switch yesterday. I was advised to replace the switch instead of trying to rebuild it. Have you worked on your switch?
Best regards, Drew
deQuincey
Quousque tandem...?
Best regards, Drew
Hi,
good to hear that you solved it,
yes, I did worked on my switch, problem is that the closing plate is delicate and brittle, and that the tabs that holds it in place must be removed and then deformed again, and they usually break
switch gets dirt inside and this causes malfunction, sometimes improvement could be get by using dielectric spray to clean internals and compressed air to remove excess
Ohmess
I wanna DRIVE!
Aiken, SC
Thanks, Drew
Drew - I would be interested in your old switch. I have a similar switch, but the connector was cut off by the seller before I bought it. I would like to swap your connector onto mine, thereby hopefully making it more valuable to a potential buyer.
coupedegrace
Portland, Oregon
Hi,
I broke one of my tabs while attempting this. I eventually got it back together with some glue. Not very elegant but it works, and I'm certainly not going to remove that plate again!
