When I got the car the roof material was lose when it was closed, so it ballooned and also flapped. I unstuck it and glued it tighter, however it then leaked water. So I unstuck it and added a foam strip inside to make it seal better. It now longer leaks, but the wind whistles through at over 50mph, hence the noise. I expect that if I drove it in the rain at these speeds it would also leak. I have now tried two different foam strips, no benefit. I don’t think that the material could be any tighter.
As I live in the UK never taking it in the rain is not a realistic way to stop it leaking, but it is the noise that upsets me the most.
What are my options?
Try a different style of sunroof, but unlikely to fit the current hole.
Try a bolt on wind deflector, that will require two bolt holes drilled and will be very non standard when viewed from any angle.
Get the entire thing removed and a roof panel made and welded in. Expensive and I lose my extra sun for slow cruising on those good days.
Any ideas or suggestions?
