WTB: Evaporator mounting bracket and connection duct
Scott Wilson
Carlsbad, California
I recently obtained an A/C evaporator, but still need the supporting parts. Im looking for the support mount and the connecting duct. Any leads would be appreciated.
i did a drawing of the connecting duct you can make easily
I'm not sure easy is the word I'd use to describe such a project. I have a duct (#13) that's ok, but not perfect. I've gotten a sheet of plastic the right thickness to build a new one. The trick is the many slight angles involved in it's construction. I'm going to make a set of templates to allow assembly of new ones, but that may take several rounds of adjustment to get things to fit nicely on first assembly. It's down the list a bit, so I won't be soon.
I have two steel mount sets (#1 & #7), both #1 damaged at different ends so I'll be able to fabricate new parts to make them both complete. It will be a relatively simple job, but again, AC is not high on the list.
Ian
