Zenith carb question
ruduger
Outside Hamilton, Ont. Canada
Greetings: I suspect I may have a float issue on my front carb. They were rebuilt 3 yrs ago, at that time we found one float to be ng. I was fortunate enough to acquire a working one. The car is running and idling fine, but the front 3 plugs are somewhat carboned up at the base. And there is a small amt of fuel seepage on the top section around the large hold-down screws. I think the mileage could be suffering also. Can one still purchase these? I'm a little hesitant to install another 40-44 yr old float, if I could find one. Also, has anyone heard of neoprene floats. They are apparently impervious to seal corrosion?
Any suggestions or similar experiences would be appreciated.
aearch
pleasant hill , ca
oem service manual for zeniths
if its leaking it would be the gasket not the float
as its air tight .
you could make a gasket i i have the oem service manual for them
send me you email address and ill forward to you
ium at [email protected]
deQuincey
Quousque tandem...?
61porsche
Dallas
Tighten
the inlet needle. Or test as described in the workshop manual. Pinch the fuel line to see if the needle holds pressure. Snug and a little bit more. It has to be tight or it will leak.
2.Sounds like your fuel level is high, so try a thicker gasket on the fuel inlet which controls the fuel level. First measure and record who put what in there.
BMW describes two thickness. Mercedes had 7. There was a reason.
3. Floats are brass. Not likely to leak. But if they do, you'll know it. Gas everywhere. Shake the float- there'll be sloshing going on. No, you can't solder it. See 4 below.
4.No, the floats are a specific weight. No substitution unless you really know what you're doing. The tolerances around the float are such that it's easy to screw it up with even the slightest gasket mismatch.
5. Hot- when the engine shuts down, heat will cause the fuel to increase volume. Sometimes this causes hot start problems and maybe the fuel you see around the screw. Got spring washers?
6. Adjustments, there a range of idle/ open throttle/ and relation to rich. Simple way is a vacuum gauge to highest and best reading. But both carbs should be about the same in adjustment. Count the turns on the idle screws and think watch adjustments. Small and deliberate.
Show some pictures of the plugs, etc.
See 1 and 2 above.
deQuincey
Quousque tandem...?
See 1 and 2 above.
i would not dare to contradict my master, :)
but my floats are made of plastic, just in case,... that being said makes no difference in the conclussion, if float is NG (thanks again Steve), or stuck in the gasket (was my case), gas will be filling everything, everywhere, including manifolds, a terrible mess
i agree we should be told a bit more about adjustments and fittings to know from were we are departing,
fuel traces in the carbs do not always mean fuel leaks, and there are fuel traces and fuel traces, it might be subjective, pics will help to set the treshold
p.s. a simple fix might be to do the top bolts a bit, as gaskets get compressed with heat, use and fuel mist i find that some thousands of km later bolts can be thigthen a bit more so any gap would be closed, maybe this works for you...?
regards
