ZF 4hp22 Automatic
Mot27cars
Elkhart, IN
Wanted to know if anyone has installed a zf 4hp22 automatic transmission in a Bavaria? Don’t know if it would fit or if bell housing issues or???
Thanks again Tom
sfdon
sfbay area
There are different models of 4hp22 with different size torque converters and different size bell housings.
The 4hp-XK with the P1 housing is biggest I believe.
Mot27cars
Elkhart, IN
Well I wonder what the smallest or best one is that would possibly fit ?
I’ll keep looking online and see if I can find something with dimension info.
pat cooks
essex
I think most from BMW would fit, the smallest would have been from a 518 M10 or 316 M10 and apart from having a small torque converter the A clutch would have less plates, it would work but might not last too long, you want a simple version with a kickdown cable not the EH electronic type with a 7 or 8 pin plug, there was a version with a two pin electronic plug AND a kickdown cable, that works ok, just ignore the wiring, look for a 4hp22 from say an E28 or E23, should bolt in easily, the bellhousing must be from an M30 engine, an M10 would bolt up but you are back to a smaller converter, I fitted a 4hp22 into my 1972 2002 and drove it for 10 years as a daily driver, worked great, very low rpm at 65-70 mph, I kept the 3 speed shifter, who needs to be able to shift it back to first?
