new integrated console for gauges and radio
well, after doing this in the central console area:
i realized that two different base plates one for gauges, and other for the radio, using different materials, ...makes no sense
so i am now designing and making an integrated piece:
it has a slight bump in the middle, a sort of transition from the radio side to the gauges side
bwalvoord
Greenville, SC
That looks really nice. With the MS3 ecu I am planning on using an android tablet and virtual gauges. Any suggestions for a flip down screen or something that could tuck away neatly?
Peter Coomaraswamy
Austin, TX
I like the contour where it steps out for the radio, will look like the stock A/C face but with gauges instead of the non functioning vents. Do you have A/C or is it not a "requirement" where you are living?
hi peter, the contour ! yes you got the point, that was the idea that originated my design, it will look pretty much the same
AC ? that is not a requirement here in the north, but funny enough as this car lived in the south i do have it integrated in the same console that is used in non AC cars
i mean my AC is a behr system installed aftermarket by bmw dealer when the car arrived in spain, the evaporator is not the usual one, but a sort of more horizontal thing that can be accomodated without the need of the stock AC face, and without the AC lateral panels and grilles that form a different angle, and without losing the space for this gauges and radio
....best of both worlds ? who knows...?
Nicad
Toronto
I think this will turn out very nicely. Looking forward to the application of fine Corinthian leather you must have locally!!
Ohmess
I wanna DRIVE!
Aiken, SC
Beautiful
I am planning to do precisely this same type of console, with the exception that I hope to incorporate the two a/c switches underneath gauges 1-2 and 3-4 (with perhaps a third switch between 2-3), all above the bump for the radio.
I have three of the four gauges, two of the three senders I need (with one installed already), gauge rings to shield the gauges in the daylight (not sure if I will attempt to slant them toward the driver), the beginnings of a wiring diagram, the vinyl to coat the console and a bit to drill the holes for the 52mm gauges.
Might it be possible to get copies of your drawings? Perhaps they could be copied actual size onto paper at a printer and mailed in a tube? Your design is great and in particular you have already worked out the spacing for the four gauges.
Arde
Cupertino, CA
I really love how innovative
we all can be with the lovely coupe
DQs project is great!
As for mine I feel I need to coin a new expression for when I overdo projects.
I am considering coupesturbations or masturprojects.
Peter Coomaraswamy
Austin, TX
Masturprojectscoupesturbation-expealadocious: If you say it loud enough it could be quite atrocious!
We all need real jobs-
