DIY handles for joining / lining / leveling the metal sheets for welding
Wladek
Gdansk, POLAND
Hi there,
was in need of something like this. Here in Poland didn't find any for purchase, so decided to make my own.
Made 10x pieces, so i think should be enough for little welding.
Time needed ca. 3 hours (for 10x), most of time spend on preparing tools and searching for needed materials.
Some tools needed (welder not shown).
Needed materials: 1. Metal closed profile 20x20x20mm, 2. Nail, 3. Metal sheet 20mm width 0,8mm thick, 4. Bolts with head for flat screwdriver M5, 6. Butterfly type nuts.
I started with cutting of closed profile, pieces 20mm length.
Then i cut profile from one side exactly in a middle. Notice - you will need thin cutting disc, so the cut wasn't too big.
After from the other side exactly in a middle i drilled a hole for the bolt.
Slide metal sheet in screwdriver crack and then weld it, sheet metal length ca. 26-27mm, width ca. 20mm.
After i drill the hole in metal sheet (same diameter as diameter of nail used for locking nut).
Locking nut i've cuted from nail, length ca. 20mm:
That's how single parts look after:
I didn't care about look of this parts, so wasn't very precise in welding or cutting. For me most important thing was that it must work, not look. Maybe when i will make some zinc plating i will add them to other bolts and nuts.
Cheers
Very nice! I generally use the large triangular magnets but I will need to buy a bunch of welding supplies (and a better welder) when the restoration begins.
eriknetherlands
Netherlands, Eindhoven area
They are really helpfull little things.
You may find that they however dont fit in tight curved panels. If you make a second batch, make a few from a 'higher' rectangular profile, use a bit longer 0,8mm plate and a longer stud and they will fit curved panels.
Verstuurd vanaf mijn SM-G800F met Tapatalk
Wladek
Gdansk, POLAND
I also have and use triangular magnets, but for floor panels need a little bit more of them and something more stiff.
Thanks, i will keep it in mind.
thestein1016
Very nice diy. If however you want to buy them, Eastwood/eBay etc has them. Roughly 10-17 bucks for a pack of 10. Also consider panel backers if you need to fill small plug holes
mulberryworks
Mr. Fixity
Jacksonville FL
