I've got Wood (veneer) let me see yours
Keshav
Germany
The best person we’ve had here on the forum offering woodwork is Bela… you can write him and discuss various wood grain options
his email contact is [email protected]
Keshav
TomHom
Germany
Hi,
just started repairing and renewing the upper layers of veneer, american walnut. Next step will be saucing to the right colour and applying several layers of lacquer
Who can see what this construction is for?
or this one?
Thomas
dave v. in nc
North Carolina, USA
Hi,
View attachment 171633View attachment 171634
or this one?
Thomas
Clamping the gauge pod?....Vacuum bags on other dash piece?....
I bought a "Food Saver" vacuum system about twenty years ago...works great. Pretty good for salmon also...
2x satin poly after stain (middle shot)...finish calms down after curing a few days, wool wax, and rub with Meguires Plastix.
TomHom
Germany
For the door trims we are working with 2bar pressure using a firehose!20231101_113745.jpg
With the other one you are right, clamping the gauge pod!
Lucas
Poland
Good evening.
I am in the process of restoring my car and I once bought a ready-made set that was supposed to be perfect. Unfortunately, the truth turned out to be brutal. The previous craftsman made the replica very ineptly and the veneer was made terribly...
Fortunately, I managed to find a specialist who would repair the previous one...
I learned from this not to buy certain elements before seeing them live.
TomHom
Germany
You are right, Lucas!
The elements are made by glued laminated veneer, with the separate layers at a 90° angle.
Over the decades humidity and water penetration dissolved the glue, especially in the left and right corners of the dashboard.
Also the coating either cracked or came of.
Repairing this not only requires the expertise of a type of craftsmanship which is hard to find nowadays, but also dedication to the beauty of wood and enthusiasm.
I could convince my neighbour, who is a carpenter, to do this job together with me in his free time. We worked on my sets, but finding some more parts we have 3 LHD sets and 1 RHD set together by now. I may give away one set but only in exchange by a set which can be restored.
But first lets find the right colouring and the apply the layers of coating.
I will report
Door trims often were exposed to water at the triangle window. The handle was often screwed on using high force resulting in a flattening of the wood.20231106_124110.jpgIMG_20231030_205852_resized_20231030_090045374.jpgIMG_20231030_205915_resized_20231030_090056889.jpgIMG_20231030_205944_resized_20231030_090056235.jpgIMG_20231030_210006_resized_20231030_090056527.jpg
Thomas
dave v. in nc
North Carolina, USA
Drew Gregg
Ft. Lauderdale
If you have to completely make the door wood pieces and the vinyl door panels, you might consider eliminating the cutouts for the ashtrays.
TomHom
Germany
I've also seen unbelievable home-made reproductions:20231106_155526.jpg
Even though 3 hours in grandma's oven the finish is not that nice! But if I put my brown leather racing gloves on it nobody will notice!
bavbob
Boston, Ma
Strip off the old stuff, glue the base layers using a syringe, 20G needle and adding a bit of water to the wood glue so it is more workable and follows gravity. $80.00 for 3M glue backed quarter sawed walnut veneer. I used no vacuum at all. Dave and I both mentioned before, avoid hard finishes like those for marine use because they will just crack with temperature changes because they are so brittle. I use single coat satin oil-based poly since I do not like that glassy look.
With what I have seen members do with their cars, you are all capable of doing this yourselves. Just a matter of the time. Learning curve is small.
