tochi
- Messages
- 148
- Reaction score
- 71
If there is a will, there is a way. ✓
I vaguely recall a similar side-of-the-road project and recollect that the two-part epoxy failed to adhere to the plastic float. There were other issues at play (loss of fluid), but after hard use, the epoxy seemed loose enough to suggest the fix was temporary. Per your explanation, perhaps the epoxy had not fully cured or the plastic float was not properly cleaned. I recall consideration of a suitably sized and shaped float, allowing a fastener to pass through to the float bottom.
